![]() Drives: 2019 Camaro SS Join Date: Jun 2022
Best way to spend $3k-$4k
I've got a daily driver (93-octane) 2019 Camaro SS M6 (non-1LE) I'm looking to improve without going completely wild. I also have about $3k-$4k to do it. The question is, what gives the best bang for the buck? Heads/cam or twin turbo is obviously out of the question on this budget...but what *IS* practical?
Looking through this forum, I see some of the following possibilities:
Anybody know if it's reasonable to do some (or all) the above in $3k-$4k? The Kooks headers alone is probably $1500-$1800 coated but not installed. The custom tune is a must for the headers to avoid CEL. From what I've seen, the Kooks and tune alone should be good for at least 20-30rwhp, probably more. And can anyone recommend someone to do the above work who's in the Atlanta, Georgia area? Preferably near Marietta? |
#2 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
Not sure which shops in Georgia as I don't live there, but someone will chime in I'm sure.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: E92 BMW M3 Join Date: Oct 2012
You'll need to add the CAI to the headers and tune as well. I would suggest going with a more budget header to stay in budget.
There are plenty of quality headers for less, and that should get you back in your budget. I would go to Vengeance Racing without a doubt. Great shop with national recognition.
J-Rod Built and Matt@FSP Tuned |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
pretty near to you. A lot of people on here have used them.
https://vengeanceracing.net/
#5 | |
I have 2" Speed Engineering Headers on my car now. I know the "premium" name brands are just that premium, but in side by side testing there is very little difference between one header vs another. 2" > 1 7/8ths" in terms of you get more bang. But in general 2" headers are if you plan to boost later more so for higher boost settings. I spent $3500 on my upgrades: LT Headers (cat delete), CAI, X-Pipe and E85 flex fuel installed and dyno tuned out the door.
#6 | |
That's how I did my build. First went with Stainless Power headers and cats, then later added the cam. Nobody who knows me would call me frugal, but as you pointed out there is no meaningful difference when it comes to quality headers made of SS and have good fitment. Plenty of cheap options that fit that mold.
#7 | |
Maybe later I might do the cam. But I figure by then I'm getting close to the 600 rwhp range and need to be concerned about the drive shaft/axles. If I ever want to launch on some stickies safely that is lol
#8 |
Having FUN in the SUN...
![]() Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
Headers + CAI + E85 + Tune
#9 | |
![]() Drives: 2018 Camaro SS 1LE Join Date: Jul 2019
#10 | |
So bottlenecking occurs. AF comes standard with 103mm opening. So no bottlenecking which can rob your tune of power gains. So from CAI to TB I'll have a direct 103mm intake system which is my intention. More Air, more gas, more power gains and less gas mileage
#11 |
![]() Drives: 2022 Camaro 2SS 1LE Join Date: Sep 2018
Since OP is trying to work on a budget, I think the LT2 is a better choice. The MSD makes more power overall, but I doubt a stock or bolt-on LT1 engine needs all the extra flow capability of a 103mm TB.
#12 | |
A stock charger SRT Hellcat pulls 10.8's with just drags. So it does matter in terms of optimal power gains as you said, but definitely the LT2 is the more budget friendly route.
#13 | |
![]() Drives: 19 CAMARO SS Join Date: Apr 2022
I have a 19 SS almost fbo just missing a throttle body and i am running an lt2 ported intake with stock throttle body. I have beat cars that are fbo msd and in terms of getting robbed from power i think the most important thing here is how good your tune nd setup are, so for a quicker throttle response from a tb and 1200 for a manifold i dont think its worth the money compared to an lt2 IM. |
#14 |
Thank you all for the info and amazing suggestions! I'll give Vengeance a call tomorrow.
Questions on headers. Numerous posts suggested going with Speed Engineering headers vs. the Kooks. First, do them come coated? I've always had coated headers on my past rides and it's always been a good investment. Second, their website offers wires and an O2 sensor extension. Are these needed? This car is a daily driver so it needs to pass emissions and not throw CEL's. I presume this means cats are needed? If so, I'm also guessing the stock cats won't fit the headers? Any advice here is appreciated. Last, I do appreciate the suggestions for E85. I have seen the power gains, but there's practically no E85 stations anywhere near me so it would be hugely inconvenient. I've also read a lot about alcohol fuels necessitating more frequent oil changes which would add to the inconvenience. Maybe a future thing but for now it doesn't feel practical. |
