Flying around Thailand
Drives: 2019 Camaro ZL1 Join Date: Oct 2020
Brightest Head lamps available
What are the best and brightest headlamps available for our car?
FrostZ, I already got your opinion and your pic. They are freak'in awesome no question; at least 3 times better than OEM. And I really appreciate you getting back to me with this. But I also want to see what else pops up on the forum. |
![]() Drives: 2003 Monte Carlo SS SLP, 2022 ZL1 Join Date: Aug 2021
Are you hunting with the Z or what? Are you trying to do an HID conversion?
Any and all options are on the table. I just saw Morimoto's on FrostZ's ride, spendy but awesome. I want to look at all the avenues. Some will be conversions and probably better, some will be plug and play and less expensive. More data equals better chance of choosing the correct path, and less chance I have to do it over again. And obviously personal experiences are welcome.
#4 | |
Limitless Imagination
Drives: 2018 ZL1 & 2022 Hayabusa Join Date: Dec 2016
I dug into this when I first got my car. If you have the cash and willing to spend it, Morimoto replacements are worth it from aesthetics to output.
We are already running HIDs in the OEM headlights and projects they used are actually fairly decent compared to other OEM projects. I couldn't really find any retrofits, without reinventing the wheel for an install. You can also change the DRL boards out for RGBW so they can be any color, there's a way to install these now (thanks to Swiss on here) without removing the lens. In the end, I simply swapped out my stock bulbs for Morimoto 5500K bulbs, $80. Definitely got some more lumens and easy to install. There's better bulbs if you want additional lumens, Osram CBB, but they're $220ish for a pair of bulbs. I've ran them on my previous car, but IMO the $80 Morimoto bulbs are a better bang for the buck.
2018 Camaro ZL1 - Black
- OEM Options: A10, Exposed Carbon, PVR, Nav, No Sunroof - Lightly Tinted GM Dark Tails, DD Side Markers, Morimoto 5000k, 100% LED - RotoFab Dry, Forgestar CF5V (ZLE Spec), Eibach Pro, AeroForce Interceptor, GT4 Tow Hook - Carbon Fiber (Satin): Radio, Shifter, Steering Wheel Controls, Shifter Top, AC Vents, Side Mirrors & Shark Fin 2022 Suzuki Hayabusa - Brilliant White Pearl & Shocker Yellow Wheels - +4 Arm, 240 OEM Wheel, Brock's CT (Ti) Exhaust, 1.25" drop, etc... |
Well you know where I stand but I actually ran Osram CBBs in my car before doing the whole upgrade, they actually are still in use in my daily. They are definitely an bit of an upgrade in light output but not nearly as much as I was hoping for, thus my decision to do a full housing upgrade.
Morimoto Headlights, AWE Touring Catback, MM Catch Can, ADM V2 Reservoir, Roto-Fab, C&R Oil Cooler, 1LE Grills
#7 |
It’s not really Bangkok, it’s out in the provinces. Actually, I will be traveling highway 2 again in a few nights and I’ll take a pic for ya. You see nothing in the ZL1. My Honda CRV, a 2008 at that, has much better lighting and it’s still really dark. Bangkok is lit, but leave the city and it can be, whoa where’s the shoulder. Not a good feeling when you’re traveling 60ish
#8 | |
#9 | |
#10 | |
One more thing to note about an LED upgrade is that hideous extra driver unit you have to tape up somewhere near the headlight, not too confidence inspiring.
#11 |
My Morimoto/HERO set was 1000 USD which is definitely stiff. The gain in light output combined with the DRL being a switch back blinker made it worth it too me. Obviously cheaper ways to get some better output but this is the crème of the crop. Here is a few comparison photos for reference.
#12 | |
#13 |
Now that I look at the photo I definitely agree it does look shorter! I can confirm it is the same though as in that photo I have the 1LE grills installed and they fit like a glove. That said I’m gonna say it’s the shadows on the other Z’s are more prominent than on the white of my car.
#14 |
Thank you Al Oppenheiser!
Nope, no change.
