![]() ![]() Drives: Chevrolet Camaro ZL1 1LE Join Date: Oct 2021
Eagle F1 Supercar 3R Tire Wear and Track Time
This past Memorial Day I took a trip out to New Jersey Motorsports Park. Got bumped from Novice to Advanced in a single day. hahahahaha Started the day running a 1:46 and finished the day with a 1:33.
Things are finally starting to gel with the car and I must admit these tires are fantastic. I'm running the Track Camber and after 2 track days the wear looks good (front tire attached). In all fairness the first track day was a slower pace and the temps were cool due to rain. How many more days do you think I can get out of this tire at Advanced Group pace? Attached are some links to footage of a couple of sessions: My first Advanced Group Sessions following the Corvette Crew (Group was combined Intermediate and Advanced... hence the Train) : https://youtu.be/JH8nEz11g_Y Last session of the day where I recorded a Personal Best after learning from the Corvette guys hahaha :https://youtu.be/V3fvDAUzPg8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
make sure to check the inside of the tires those seem to cord before the rest but most zl1 1le guys get 2-3 days out of a set and they are not cheap! about 2200$ on tire rack or so if you have usaa insurance you can get a discount on goodyear.com
#3 | |
I'm going to put the car on the lift over the weekend and inspect just to satisfy my curiosity. |
tire wear looks good tho whats your camber and toe set to?
these cars love camber im running -3.5 f -2.5 f rear and same toe as you i would put some more camber in them next set but overall looks good
#7 |
![]() Drives: 22 ZL1 1LE A10 Join Date: Feb 2022
#8 |
camber plates and full spl parts kit
#9 |
![]() Drives: Chevy Camaro ZLE Join Date: Mar 2022
I just bought a set of these as an upgrade from the SC3s. I am testing them out on track this weekend. I am hoping to get more than 2-3 days out of them but we will see.
#10 |
Shadow Gray '19 ZLE M6
![]() This must be you in my YouTube comments!
PPF | Paint Correction | ZL1 Addons Rock Guards | ZL1 Addons Lift Pads | ZL1 Addons Feather Lite Tow Hook | JWM Smoked Sidemarkers | Wildhammer Smoked Rear Reflectors | JWM License Plate LEDs | RotoFab CAI | ADM IC Reservoir v2 | BC Forged RZ05 | SPL Toe Arms | BW Brake Deflectors | CMS Roll Bar | Schroth Profi II ASM Harnesses . Sold: '99 Trans Am (bolt-ons & cam) | '00 WS6 (bolt-ons, heads, cam, 12 bolt) | '05 CTS-V (bolt-ons, short throw) | '10 SS/RS M6 (short throw, CAI, coilovers, LTs, catback, JRE tune) | '01 WS6 YouTube |
#11 |
#12 |
![]() Drives: 2019 ZL1 1LE Join Date: Feb 2017
The thing to watch with these tires is the inside shoulder. If you start with the low 24-26 psi recommended pressure and go 10/10th's right away, that shoulder gets destroyed pretty quick. It's best to do 2 or so lower speed laps to let the tires come up to temp first.
Otherwise that outer wear looks fantastic. If the car feels a little pushy mid-corner, I'd add more camber if possible or go one position stiffer on the rear sway bar.
Old: 2017 SS 1LE
Old: 2017 ZL1 Current: 2019 ZL1 1LE |
#13 |
If you have a square 305 set up and can rotate tires front to back, left to right. You MIGHT be able to get 3 track days on a set of tires. Depends on how hard you drive and how hot it is. Normal 325 and 305 on a zle will get 2 track days tops driving hard.
2022 Camaro Zl1 1LE, e85, Roto Fab and tune
2020 Colorado ZR2 Dusk edition 2021 Mustang Mach e |
#14 |
I just purchased the other day from tire rack. $1800 shipped. They have gone up -- last year I bought a set for just under $1700 shipped.
