![]() ![]() ![]() ![]() Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
Cam and Rocker question
My previous car was a Gen II Viper. With that car the rockers (valve train) could be changed from 1:6 to 1:7 ratio and it gave a exhaust note a very aggressive chop at idle and added a few horsepower.
Are the LT4 stock cam specs such that a rocker ratio upgrade could induce a noticeable chop without having to do a cam swap? Here’s an example. This is stock cam and stock heads except for the 1:7 rocker upgrade. http://youtu.be/_LxjHtuQTec |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
That's strange. I've never seen a set of higher ratio rockers arms affect the idle that much. You typically gain a little more lift with higher ratio rockers but its typically the LSA of the camshaft that affect idle sound.
#3 | |
For info: 708 Stock Viper Cam: Duration at .006” lift intake = 288 deg Duration at .006” lift exhaust = 296 deg Duration at .050” intake = 220 deg Duration at .050” exhaust = 230 deg Intake Center line = 117 deg Angle between lobes = 114 deg Intake lift at lobe = .321 Exhaust lift at lobe= .321 |
![]() Drives: 2018 Camaro ZL1 Join Date: Nov 2021
Lt4’s already use a high 1.8 ratio rocker.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1SS NFG A8 Join Date: Aug 2017
All LT engines use 1.8 rockers. As did the LS7.
There is no low hanging fruit on this platform by doing this mod. You want cam chop then put a cam in with some positive overlap.
2016 NFG 1SS A8
