![]() Drives: 2017zl1 Join Date: Aug 2018
Broken armonic balancer
I broke my harmonic balancer and replaced it and now it won't run While I was there I replaced the oil pump and Never took the gears loose for the Cam or the chain put it back together and it will not run says that it can't sync the timing between the crank and the Cam Any ideas would be greatly appreciated
Thank you Al Oppenheiser!
This is the same car with the 2.9 whipple? I presume the code is P1345: Crankshaft Position to Camshaft Position Correlation ?? And no additional codes telling which (if either) sensor is reading faulty?
You can try: 1. disconnect battery for 20 mins. 2. check and reseat all the connections to the crank PS and cam PS. 3. check for burned or rubbed harness & wires (common if you have headers). 4. check for arcing plug wires (also common with headers and/or aftermarket plug wires). 5. fire the parts cannon (not recommended). |
