Old 05-29-2022, 03:28 PM   #1
2004YZFR1
Drives: 2020 Chevrolet Camaro Coupe 2SS 1LE
Pro Clip Dash mount?
I am thinking about using the Pro clip dash mount. So I can film my track runs and see my lap timer. I wanted to see who else uses this style on their 1LE. I don't want to leave it on the dash all the time though.
I see that it has some 3M tape on the mount. I don't want to use that, since I will only have it mounted on track days.
So have any of you used it without the 3M tape and if so does it stay secure enough?
And I did use the search engine but didn't find my answer.
Thanks
2004YZFR1 is offline   Reply With Quote
Old 05-29-2022, 04:08 PM   #2
Christian1LE
Drives: 2004 BMW 330CI, 2022 1SS 1LE
I have the console mount, not the dash one. I installed mine with the 3M tape but it came loose anyways. So now it basically just runs w/o the 3M tape, stays on 99% of the time. But I've had it fall off sometimes during a track run. You just have to make sure it's wedged in there good before you go out. I plan on getting new 3M tape to use. I actually even have the phone mount coming loose and falling off during a lap but I don't have that video uploaded.
Christian1LE is offline   Reply With Quote
Old 06-09-2022, 03:22 PM   #3
Vivid_O_1LE
Drives: Chevy Camaro, Dodge Charger
i use a ram mount for my phone on track days that gets paired up to my racebox mini. It does a good job of holding the phone securely.
https://www.amazon.com/dp/B00DI2W24O...fix=ram+x+grip
2022 SS 1LE 2SS 6MT on order. BDZHD3
Vivid_O_1LE is offline   Reply With Quote
