![]() Drives: Turbo 6.2 Join Date: Feb 2019
Direct Port Meth
Who has it and what made you change from nozzles in the intake tube to the 8 nozzles.
I currently have alky system feeding triple nozzles in my intake tube before the throttle body. Two m15 and one m10. Obviously, my combo relies on the meth as additional fuel. I have converted to a complete LT4 Fuel System, with a DSX AUX pump and 32% cam lobe. I am thinking about sending my pro charger intake manifold to Pro Meth for their direct port system to remove the nozzles from my intake tube. What do I need to know or think about before making this change?
2016 Twin Turbo Camaro SS - 968hp/970tq 8.9@153
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100 |
#2 | |
Moderator
#3 | |
I sold my port injection manifold for this non port. I really like the idea of keeping one ecu. If I ever want to turn it up more the fore low side, big bore hpfp and +30/60 injectors are easily able to be purchased. My reasoning for the direct port meth is exactly about preventing a lean cyl. The last two motors showed an uneven amount of burn/crud on clys which tells me the meth/air wasn't being distributed as well as I hoped. I believe thinking the oem manifold would support an engine making double the power with FI and triple nozzle meth being spraying into the throttle body is a bad bet.
#4 | |
Moderator
Glad you caught the fueling distribution issue before it became a problem!
