Old 05-24-2022, 03:34 PM   #1
Osbornsm
Drives: 2018 SS 1LE
Exclamation $$ Here's the deal $$
I just purchased the SS 1LE SuperCar 3 Tires 285/30/20 - 305/30/20
For $1,325 installed.
Thank you DiscountTire
There is a $75 discount from Goodyear
AND
There is a $50 discount from DiscountTire.com
Just spreading the savings :-)
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si
Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8
Results: 470 hp / 447 tq
Osbornsm is offline   Reply With Quote
Old 05-24-2022, 06:08 PM   #2
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Sounds like a good deal to me!��
Old 05-24-2022, 06:19 PM   #3
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
For as long as they last, it's not an especially great deal. It was about 1700 for PS4S from Costco installed and they last 2x easy, possibly to 3x.
2018 2SS 1LE
2023 Colorado ZR2
2022 Stinger GT-line AWD
JamesNoBrakes is offline   Reply With Quote
Old 05-24-2022, 06:40 PM   #4
nprario
nprario's Avatar
Drives: 2017 1ss 1le HBM
Not bad at all. If you are a member and can go through USAA you will do better. I got $1,160 installed using their perks program.
nprario is offline   Reply With Quote
Old 05-24-2022, 06:50 PM   #5
N Camarolina
N Camarolina's Avatar
Drives: 2021 2SS 1LE
Perhaps so. But the SC3 has considerably higher grip level, does it not? If you are talking tires for DD, then I'm totally aligned with the PS4S or ECS approach (no need for a stickier tire because you can't really use it on the road).
But on the track, that's a different matter. I was under the impression that for a track tire, the grip and longevity for the SC3 vs alternatives is pretty impressive. Certainly better overall than a CUP2
N Camarolina is offline   Reply With Quote
Old 05-24-2022, 07:10 PM   #6
Hostile_1LE
Hostile_1LE's Avatar
Drives: 2020 Camaro SS 1LE | Satin Steel
Dude what… I got the SC3’s last Wednesday, orders them through discount and had them mounted by discount… was $1700.
Hostile_1LE is offline   Reply With Quote
Old 05-24-2022, 07:22 PM   #7
Kmeleon
Drives: 2018 NFG 2SS 1LE!
If you track the car then its a darn good deal.
Kmeleon is offline   Reply With Quote
Old 05-25-2022, 07:21 AM   #8
FlukeSS
FlukeSS's Avatar
Drives: 2020 Camaro 2SS A10
AND
Forgive me, but I bought Eagle SC3's for the rear, and Advan V105's for the front and it only cost me about $900
Are we sure this is a deal? Or do you just happen to live in a higher economic region?
Never mind I see you are in Illinois. Might as well be LA. My question was answered.
Old 05-25-2022, 07:31 AM   #9
Crushin_LT1
Crushin_LT1's Avatar
Drives: 2021 LT1 6spd
Discount tire or discount tire direct? I've noticed the prices aren't always the same between them.
Current: 2021 LT1 Camaro, 6spd, Crush, Corsa NPP, GMPP CAI, Soler Performance Throttle controller
Previous: 1997 V6 Camaro, 5spd, Black
Crushin_LT1 is offline   Reply With Quote
Old 05-25-2022, 08:52 AM   #10
Osbornsm
Drives: 2018 SS 1LE
I purchased via the discountTire.com and got the install included in the price.
Old 05-25-2022, 10:52 PM   #11
JamesNoBrakes
Drives: 2SS 1LE
Not in my experience, it's marginal better dry, significantly worse in slight moisture/rain. Significantly worse tram-lining. The SC3 is sticky, but it's not much better than a PS4S and the PS4S does a lot of other stuff significantly better. For the tread wear/life, it's not nearly sticky enough IMO.
2018 2SS 1LE
2023 Colorado ZR2
