Old 05-23-2022, 01:59 PM   #1
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
TERMINATOR CAM CLIPS ???
Hey Team... I have a quote for one of JRE's terminator cams with the following specs, and wanted to see how it sounded but cant find anything on youtube, and i dont do any social media, so i cant check facebook, etc...
Does anyone else have this cam, and can share some clips of idle, and or any driving impressions or issues?
222/234 .635/.635 114LSA 112 ICL +32%
Old 05-23-2022, 02:25 PM   #2
Crusher Camaro
Drives: 19 ZL1
ask me next month.
Currently have kooks 2" long tube system
Roto fab (non big gulb)
flex fuel
JMS BAP
remote tune from Ted.
Have a few parts in the shop, started pulling the engine this weekend.
adding JRE rough idle cam. C5 timing chain, LS7 lifters, rocker trunnion upgrade, 95MM throttle body, ATI with 8% overdrive.
Would love to be done in a week, works not gonna let me have the time.
so wish I had a two post installed right now!
Crusher Camaro is offline   Reply With Quote
Old 05-23-2022, 03:09 PM   #3
SOCAL.M6.ZLE
Yes sir... will do...
you doing this all yourself?
Old 05-24-2022, 06:33 PM   #4
Grumpy1
Grumpy1's Avatar
I think he has a vid on his Facebook page with one.
Grumpy1 is offline   Reply With Quote
Old 05-24-2022, 09:37 PM   #5
SOCAL.M6.ZLE
I know… but I don’t have any social media, and can’t find any on youtube
Old 05-27-2022, 09:23 AM   #6
SOCAL.M6.ZLE
Originally Posted by Crusher Camaro View Post
ask me next month.
flex fuel
JMS BAP
That is super motivating to see... hope it all goes well, and would love to talk to you when your finished! So, your removing the motor, becuase your changing the chain, that requires you to remove the pump, which means your dropping the pan correct?
Are you also doing the VVT delete cover?
Old 05-27-2022, 09:24 AM   #7
SOCAL.M6.ZLE
Can someone share a facebook video here?
I cant find one anywhere...
Old 05-27-2022, 07:56 PM   #8
Crusher Camaro
Drives: 19 ZL1
Didn’t want to pull the radiator or dump the a/c.
Putting new timing chain on, yes dumping the pan and oil pump.
Going to 3D print some oil pump alignment brackets, gotta draw them up first.
Thought about the valley cover and even the ls3 cam drive front cover from LME. Gonna stay stock parts for now. May swap if I do a whipped 3.0 next year.
Old 05-29-2022, 09:45 PM   #9
Grumpy1
Grumpy1's Avatar
See if this helps, not oem exhaust
https://m.facebook.com/search/top/?q...urce=typeahead
https://m.youtube.com/watch?v=aMe5taomHWY
Old 05-29-2022, 11:29 PM   #10
SOCAL.M6.ZLE
Thanks Grumpy... that sounds killer!
Old 05-30-2022, 09:34 AM   #11
Grumpy, just out of curiosity, yours is the rough idle terminator cam, right?
Old 05-30-2022, 02:16 PM   #12
Grumpy1
Grumpy1's Avatar
Clips were not of my car...
I too was interested in his came and remembered i had found these...
Old 05-30-2022, 09:53 PM   #13
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
"222/234 .635/.635 114LSA 112 ICL +32%"
If this is the specs of his cam its ok. There is 0 overlap so much not much of a chop.
Most are in this range, mine is a 229/241 .635 116 LSA, 3 degrees of overlap. In an auto this would be about it without a stall. I am making power all the way to 7k rpm.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
