Old 05-16-2022, 10:49 AM   #1
xc3ss1v3
Drives: 2016 Camaro SS
Fluctuating Temp Gauge
Hello all. I've seen several threads pertaining to a zeroed out or "cold" temperature gauge and that usually being a faulty coolant temp sensor, but what about a gauge that only seems to be flopping back and forth?
Mine will sit around the standard 200-210 degrees, raise up, and then fall back down. It'll do that several times before rising up to the 260 range and the car alert going off. Typically, I've shut the car off either right as this happens or before. When I turn it back on, it'll sit at the normal mark again and repeat the process.
Could this also be a simple switch of the sensor? Or is this more indicative of the thermostat malfunctioning?
xc3ss1v3 is offline   Reply With Quote
Old 05-16-2022, 11:10 AM   #2
ctrlz
This sounds like a failing thermistor, which is the functional part of the coolant temp sensor.
Typically they fail open, but they can also drift.
Old 05-16-2022, 11:49 AM   #3
LT1ornothing
Drives: 2020 LT1 M6
There could also be air in the system if you had the coolant changed recently.
Old 05-16-2022, 12:51 PM   #4
xc3ss1v3
Interesting. It's only a $20 part so I guess worth it to change and see. From videos it looks like it's reachable with an extension and swivel. Is that the case as far as you know?
Old 05-16-2022, 12:52 PM   #5
xc3ss1v3
No changes to the coolant system in the couple months I've owned and this just started. Though, I will say the fan has been running in the "louder than you'd think it should" state since I bought it. I'll also say, the reservoir doesn't appear to be to the fill line
Old 05-17-2022, 09:01 AM   #6
ctrlz
You could unplug it and check the resistance against the expected value. It is probably a 10k NTC thermistor and just check it with the engine cold (so about 70 deg) and then once warmed (so about 200 deg).
I'll see if i can find the chart in the repair manual. But charts for 10k thermistors are all over the web. This one's in celsius:
https://cdn.shopify.com/s/files/1/02...g?v=1588786764
Here's the chart from the repair manual:
SPECIFICATIONS > TEMPERATURE VERSUS RESISTANCE - ENGINE COOLANT
TEMPERATURE SENSOR
Temperature Resistance
150°C (302°F) 42 to 44 Ω
140°C (284°F) 53 to 57 Ω
130°C (266°F) 68 to 72 Ω
120°C (248°F) 88 to 92 Ω
110°C (230°F) 114 to 120 Ω
100°C (212°F) 151 to 159 Ω
90°C (194°F) 203 to 215 Ω
80°C (176°F) 275 to 293 Ω
70°C (158°F) 379 to 405 Ω
60°C (140°F) 532 to 572 Ω
50°C (122°F) 762 to 824 Ω
45°C (113°F) 921 to 997 Ω
40°C (104°F) 1118 to 1212 Ω
35°C (95°F) 1366 to 1484 Ω
30°C (86°F) 1683 to 1829 Ω
25°C (77°F) 2088 to 2266 Ω
20°C (68°F) 2608 to 2828 Ω
15°C (59°F) 3289 to 3567 Ω
10°C (50°F) 4182 to 4532 Ω
5°C (41°F) 5356 to 5800 Ω
0°C (32°F) 6914 to 7484 Ω
-5°C (23°F) 8994 to 9732 Ω
-10°C (14°F) 11796 to 12762 Ω
-15°C (5°F) 15589 to 16871 Ω
-20°C (-4°F) 20791 to 22517 Ω
-30°C (-22°F) 37991 to 41273 Ω
-40°C (-40°F) 72230 to 78834 Ω
