Old 05-14-2022, 11:20 PM   #1
RacerXnh10
Drives: 2017 Camaro 1LE
Porting
Hello
I will have the motor apart this week and wanted to get some input on porting heads, TB and or IM. 2017 SS 1LE, Roto fab intake, long tub headers, gutted cats, e85.
I reached out to Pray a week ago, haven't heard back.
I've seen a lot of mixed info when searching. I wanted to see what people thought about potential gains vs cost. I do track the car, need to keep it appearing stock, so not interested in the aftermarket IM.
Thanks!
RacerXnh10 is offline   Reply With Quote
Old 05-15-2022, 12:42 AM   #2
95 imp
Dumb Ass Deluxe
The LT2 IM is the way to go.
Old 05-15-2022, 11:05 AM   #3
LT1ornothing
Drives: 2020 LT1 M6
Originally Posted by RacerXnh10 View Post
Hello
Thanks!
Ported heads should really be installed with a cam, upgraded valvetrain, and D.o.D. delete at the same time to realize their power gains. There are small gains to be had porting the LT1 TB and IM, but you are better off upgrading to a LT2 IM and LT5 TB. Sounds like you are torn up between FBO and heads and cam. If that is the case, better to do heads and cam if the motor is out.
Old 05-15-2022, 05:05 PM   #4
RacerXnh10
I am - its very tempting to head down the rabbit hold once the motor is out.
The biggest thing holding me back is this car is at the very top of the class points wise in a local club and if I do anything to it I will be at the bottom of the next class (would put me against c7 grandsports, c5z's, 911s etc) There's no way I'm getting a cam through tech without raising some eyebrows. On the other hand I don't want to add 2 weeks and a few grand to the project to pick up 15hp. Sounds like I can't be half pregnant - I'm either in or out.
Old 05-15-2022, 06:53 PM   #5
6spdhyperblue
Drives: 2SS 1LE
In that case I would run ported heads and a oem LT5 cam so you can run non afm lifters
Old 05-15-2022, 07:08 PM   #6
LT1ornothing
Drives: 2020 LT1 M6
I agree, the LT5 cam is dirt cheap, get rid of the junk valvetrain, do DoD delete, decent lifters, LT2 IM, LT5 TB, maybe mill the heads while they are ported for a slight compression bump.. You can raise the rev limiter a bit safely and it will make more power 4K-7K rpm. It will sound identical to how it currently sounds and should slip right through the tech unnoticed.
Old 05-15-2022, 08:58 PM   #7
Duramacr1
2Spdsy
Duramacr1's Avatar
Drives: 2021 Camaro LT1 A10
C7 GS, c5Z , etc lose to a properly built LT1 will H/C. Hell even my bolt on car destroys an LT4 ZL1 or Z06 with minimal mods . Your normal H/C 6th Gen should run low 10’s , high 9’s full weight. Don’t be afraid of the challenge, 6th gens do very well against other cars .
Duramacr1 is offline   Reply With Quote
Old 05-15-2022, 10:20 PM   #8
RacerXnh10
Running road course stuff, the extra weight and lack of tire hurts. It may still be competitive up a class, I could do a fair amount of weight reduction and put a nice 305 square setup on if I bump up, but those guys are real fast.
Old 05-15-2022, 11:55 PM   #9
Duramacr1
2Spdsy
Duramacr1's Avatar
So sorry . Didn’t see you were running road course .
Old 05-18-2022, 03:32 PM   #10
4thCamaro
4thCamaro's Avatar
Drives: Chevy Camaro 18’ SS 1LE
Hello
Thanks!
If you're going to port the heads then get a cam. I just had the conversation. You're going to spend the same on porting the heads and install with or without the cam so you might as well. Pored heads are worth it, whether it's worth the cost is up to you to decide. I want heads and cam but won't pull the trigger on that until the off season.
FBO 18’ SS 1LE
4thCamaro is offline   Reply With Quote
