05-14-2022, 06:38 AM | #1 |
Drives: None Join Date: Apr 2022
20x8.5 Drag radial
What is the best drag radial for a stock lt1 wheel? It’s a stock stick car, if that matters.
05-16-2022, 11:31 AM | #2 |
No one with an lt1 is running a drag radial?
05-16-2022, 01:07 PM | #3 |
Drives: 2022 Camaro LT1 M6 Recaro NPP Join Date: Nov 2021
Ditto. I was wondering about that same thing for my LT1. So far the only one I’ve found is 275/35/20 but I don’t think it will fit a 8.5 rim. I hope someone can find something that will fit. I really don’t want to buy more rims.
2022 LT1 M6 Recaro Red Hot NPP red calipers red seat belts GM short throw shifter GM strut tower brace GM CAI Long tube headers YYZ springs LT2 intake E85 MightyMouse catch can
1992 RS 5.0 5-speed, 1995 Z28 Auto, 1999 WS6, 2007 Trailblazer SS. |
05-16-2022, 02:36 PM | #4 | |
As BUD357 mentioned there are sizes that come close to fitting based on manufacturer recommendation. But your factory wheel is technically too small. If I were in your situation and wanted to keep factory wheels, I’d buy a set of the Nitto’s and rear factory SS wheels. There are plenty of those wheels for sale and at a reasonable price. Here are the 20” tires sizes available for the NT555RII‘s.
05-16-2022, 07:29 PM | #5 |
Thank you Trochoidal. I guess I will start looking for 20x9.5 carbon flash wheels from an SS
05-16-2022, 08:25 PM | #6 | |
Here’s a pair of rims still for sale based on the last post from OP. 2 rears, 9.5”, carbon flash $500. YOLO! (No pressure) https://www.camaro6.com/forums/showt...=599294&page=3
05-17-2022, 09:16 AM | #7 |
275/35/20 555r2 will fit the 8.5" rim fine. I run a 305/35/20 555r2 on a 9.5" rim and it's fine and been fine for 5yrs now. Never had a issue putting a Nitto on a rim that is .5" narrower then recommended since they tend to run narrow for their size anyway. You will have a slight bulge but it will wear fine and provide a lot more traction then your factory tires.
2016 NFG 1SS A8
