Old 05-12-2022, 10:41 PM   #1
Contagion
Drives: 2019 Camaro ZL1
Exclamation No Crank, Possible Clutch Position Switch?
The other day I went to start my car and it kept prompting me to push brake and clutch to start. I believe I narrowed it down to the CPS but was wondering if anyone else has seen this. I’ve tried disconnecting the battery, and various other key fob tricks. Maybe a relearn on the clutch? Any advice is greatly appreciated.
Contagion is offline   Reply With Quote
Old 05-13-2022, 10:21 AM   #2
ctrlz
Both brake and clutch?
That seems weird. Maybe that's how it works when parking brake is not set. I always have mine set.
Agree, if this persists, sounds like a pedal position sensor problem on one of the pedals.
Old 07-10-2024, 06:54 AM   #3
Donjazz
Drives: 2022 LT1 Riverside Blue
Did you figure out what was causing it not to start?
Donjazz is offline   Reply With Quote
