Old 05-10-2022, 04:15 PM   #1
synolimit
Drives: 22 ZL1 1LE A10
Baseline and rotofab results ZL1 1LE
Nothing special but wanted a baseline incase I do stuff in the future. Looks like I should of made more HP since the run was done at 6350rpm vs the first at 6550rpm.
MBRP race CBE 572hp, 574tq
Vs
Rotofab CAI 585hp, 581tq
22 ZL1 1LE 1600 miles
A10 6th gear
Dynojet using the correct SAE, no cheating here.
Not sure if it matters but I don’t know if traction control was on or what mode the car was set in.
synolimit is offline   Reply With Quote
Old 05-11-2022, 10:53 AM   #2
JSH
JSH's Avatar
Drives: '20 ZLE
I don't believe that you have valid results so far upon which you can form a judgement. Mine made 572 wheel totally stock so something is off here.
Vs
A10 6th gear
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 05-11-2022, 12:15 PM   #3
synolimit
Lol it’s 100% accurate! You think an intake and exhaust add power? Haha.
And I used SAE. If you used STD and got 572 which is equal to my 572 then the CBE did add something since you’d be 2% lower if you switch to SAE. But if you used SAE and got 572 then like I said, CBE don’t add power.
