![]() Drives: 2017 Camaro ZL1 A10 Join Date: Jan 2017
Compression test result
I had a compression test done on my 2017 ZL1 (24K miles) after a cam install just to check it. I'm trying to find what the expected values are and I'm not finding anything, I also looked through the service manual.
Does anyone know what the expected values are for our engines? Here are my results:
Average : 167 #6 is the lowest but still within 10% of the others. GM allows 30%.
2017 ZL1 Black, A10
Build: Magnuson 2650R, 103NW Throttle Body, Rotofab Big Gulp, Kooks 2" headers, Catless, AWE Touring exhaust, JRE Smooth Idle Cam, Katech Oil Pump, Elite Catch Can, JMS Fuel Booster |
![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS Join Date: Aug 2016
Problem with comparing to other's cranking numbers is that you've changed the camshaft. Bigger cam is going to cause a lower cranking compression number than you would have seen while the stock camshaft was still in there.
#3 | |
I've threatened to test mine but have thus far procrastinated.
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq |
Your right on the money for an Lt4 with 10 compression ratio. The Lt1's generally are 200 to 210 or maybe a little higher with a 11.5 compression ratio. To me what's most important is the tightness of the cylinders, 167 to 170 is just stellar. Your good to go
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '21 ZLE A10 Join Date: May 2012
looks good...old school trick is to put a squirt of oil in the lowest cylinder and see if the compression increases significantly. The spread is reasonable and the new cam's overlap (intake and exhaust open at the same time) will lower cranking compression
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: like an old lady Join Date: Jun 2012
my LT1 consistently shows 265+ lb compression. tested it several times over a 2 year span. engine always cold, after sitting at least a week.
#7 |
![]() ![]() Drives: 2018 Camaro SS 1LE Join Date: Jul 2018
265 psi??? Is this a quality gauge?
#8 |
yes. i had the same idea & used 2 different gauges. both are reliable. lowest was 261ish, highest was 273.
