Old 05-06-2022, 04:42 PM   #1
removeb4flight
Drives: 2020 Camaro RS
Knock sensor after cold air intake for V6
Installed a cold air inductions cold air intake on my 2020 Camaro 3.6L V6 and had it with no issues for a month until a service engine light comes on and I go to auto zone and they tell me its a knock sensor. I took my car to local chevy dealership since its under warranty and they said to run premium. Is this normal? the site I got my cold air intake said it needed no tune or anything.
removeb4flight is offline   Reply With Quote
Old 05-06-2022, 08:44 PM   #2
HCI2000SS
HCI2000SS's Avatar
Drives: 2018 Camaro V6/RS
There's something else going on. Running premium is not the answer
HCI2000SS is offline   Reply With Quote
Old 05-06-2022, 09:45 PM   #3
S.Macias
Monterey County Camaros
S.Macias's Avatar
Drives: Stock 2016 Camaro V6
A cel would come on in the first few minutes if it was the intake. But with all my bolt ons I never got a cel. I would have AutoZone pull a code asap once it's come on. Code might even be stored.
Instagram: @smaciasracing
S.Macias is offline   Reply With Quote
Old 05-07-2022, 05:24 PM   #4
removeb4flight
I took it to auto zone the first few hours it popped up and gave me a knock sensor code and immediately scheduled a service appointment with chevy. I received the car today and no codes have popped up since. Unsure what to do at the moment
Old 05-07-2022, 05:29 PM   #5
removeb4flight
The chevy dealership service workers said that they think its the cold air intake causing it. Could this be it? I don't want to give up my intake system
Old 05-07-2022, 11:58 PM   #6
S.Macias
S.Macias's Avatar
I would start with checking for vacuum leaks. Make sure nothing is loose. Might even give the maf a quick cleaning.
From there, I would check the spark plugs. Fairly easy to check. Took me 90 minutes to replace and that was taking might time.
Once it's all checked I would drive as normal until it pops up again. Sometimes the computer has trouble adjusting for air flow changes which is why they recommend disconnecting the battery during install and letting the car idle for 10 minutes before driving it with the new cai
Old 05-08-2022, 07:50 AM   #7
HCI2000SS
HCI2000SS's Avatar
That CAI is designed to work with your stock tune on 87 octane. Just to be clear your car has no other mods, and the tune was never messed with in any way correct?
Old 05-14-2022, 11:37 AM   #8
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
could get an odb2 connector pretty cheap and read some of the sensors to see if you are running very lean or rich.
some cai's remove air straighteners in the name of air flow obstructions... and this can impact the maf getting accurate readings.
if you are not leaking anywhere that is. as that is the most likely cause for running too lean and getting knock.
Old 05-14-2022, 12:46 PM   #9
Gen6cyl
Drives: Chevy Camaro 2021 ,rs, v6, manual
I have not changed my intake from stock because I believe it can compromise the air flow sensor and hurt performance.I keep the engine cover off and use only 93 octane.I got my 21 v6 new and now at 30k miles it runs great.I didn't start using 93 until 18k miles, my mistake.
Gen6cyl is offline   Reply With Quote
Old 05-16-2022, 09:24 PM   #10
Matt1LE
Matt1LE's Avatar
Drives: 2020 3LT Camaro 3.6L 1LE
Let us know how you make out. Was thinking of buying a CAI for my car.
Matt1LE is offline   Reply With Quote
Old 05-17-2022, 06:34 AM   #11
Gen6cyl
I changed my air filter last weekend.Oil was in the intake,it went through the air filter and drained a little out drain hole in air box.Instead of keeping oil at full I will keep it at half way on dipstick marks.I looked at filter 6 months or so ago and intake was dry.I quess last oil change I should have not filled to top mark. Still runs good.
Old 05-17-2022, 12:18 PM   #12
ctrlz
I am not sure what the minimum recommended octane is for the V6. But anything above the minimum will only hurt performance (and your wallet), unless the car is modified to take advantage of the higher octane.
It's called "power-robbing premium" for a reason!
Old 05-17-2022, 01:30 PM   #13
Gen6cyl
I drove my first 18 k miles on 87, my last 12k on 93. I know what it runs best on.
Old 05-27-2022, 10:21 PM   #14
cellsafemode
altitude, engine load, heat will potentially make 87 knock. pulling timing is situational and will happen less often with higher octane.
but if you are going to drop 300 on replacement intake filter, you might as well get a trifecta tune. you won't find a more noticeable upgrade to the v6 compared to a tune other than forced induction.
