Old 05-04-2022, 07:39 PM   #1
KamZL1
KamZL1's Avatar
Drives: Z06
How much WHP
so i just watched rpm do headers, intake, exhaust, tune and hit 628/698. baseline at 570 or so. does this seem like reasonable gains or what? what would you see with flex tune added to same mods if so?
KamZL1 is offline   Reply With Quote
Old 05-04-2022, 07:54 PM   #2
JSH
JSH's Avatar
Drives: '20 ZLE
Yes, those numbers look comparable to those posted by others here previously. Headers and tune will make probably 30-40.
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 05-04-2022, 08:49 PM   #3
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
They are a little bit higher dyno side because they are in STD. But 650-675 with flex fuel. Basically like Teds package from Jannetty.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 05-04-2022, 10:28 PM   #4
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
It seems if you can swing FF, that's the hot ticket. There are many upsides that have been posted all over the place.
'20 ZL1 Black "Fury"
