Old 05-04-2022, 05:24 PM   #1
Smokin19
Drives: 19' ZL1 A10, w/pdr
My new build
Finally completed the build I have always wanted and it has exceeded all my expectations.
Started with just stock tune and rotofab intake (A10). Blake Leonard started Top Speed Cincy about 4 years ago after working for WeaponX. WeaponX quit building engines. It is the same shop with a Mustang dyno but, Blake owns the shop now. Here is the build which was my want list.
Stg II btr cam w/ 38% fuel lobe, .660" lift Platinum spring kit, Titanium retainers,
chrommoly push rods.
STOCK heads and vlvs
GM Gen V cam bolt
WT Camshaft bolt
DSX low side kit
NW 103
Rotofab big gulp
2" ARH into 3" with cats, stock muffler
Weapon X triple ht exchangers
MM cc
Kong X port
IW V3 ZL1 8-ribbalancer w/ Metco ring
BTR GEN V/ afm delete kit
BTR Gen V VVT lockout
ARP head studs, Johnson lifters
ARP LT-4 crank bolt
TCM tune
Incedentals:
Z26 brake pads
BMR Lockout kit
AMP billet thermostat housing with 160 stat
Brisk RR 12S Plugs
On a Mustang loaded dyno it pulled 720 rwhp, 634 lbs tq, 15 psi boost, 7th gear pull
Smokin19 is offline   Reply With Quote
Old 05-04-2022, 05:30 PM   #2
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Looks good and nice numbers!
Old 05-04-2022, 06:18 PM   #3
Smokin19
Thanks
Guys like you have helped me learn about these cars and specifically engine builds.
Old 05-04-2022, 06:18 PM   #4
JSH
JSH's Avatar
Drives: '20 ZLE
Awesome build. I really like the look of the Eaton. Whose lid is that? I'm curious why you stayed with stock heads and valves, an aftermarket set of which makes a dramatic difference.
GM Gen V cam bolt
WT Camshaft bolt
DSX low side kit
NW 103
Rotofab big gulp
MM cc
Kong X port
ARP LT-4 crank bolt
TCM tune
Incedentals:
Z26 brake pads
BMR Lockout kit
Brisk RR 12S Plugs
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 05-04-2022, 06:38 PM   #5
Smokin19
Thanks
The lid is made by WeaponX and is only cosmetic but, boy does that blower whine come thru especially with a big gulp.
Looking at previous builds with ported stock heads or aftermarket was not in my budget at this time. We determined the cost for at least porting the stock heads would not gain that much for the cost. My goal was the cam, everything else was needed to support that with the budget I had. Today's ride showed me this car does not lack anything for street use only.
Old 05-04-2022, 11:20 PM   #6
Xelor
Drives: 2022 ZL1
Nice Build. Looks Badd Azz
Xelor is offline   Reply With Quote
Old 05-05-2022, 05:47 AM   #7
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
Nice work, looks great
pauly1119 is offline   Reply With Quote
Old 05-05-2022, 08:10 AM   #8
CruiznZ
CruiznZ's Avatar
Drives: 2018 Camaro ZL1 1LE
Looks great. How does it sounds with the bigger cam and stock muffler?
CruiznZ is offline   Reply With Quote
Old 05-05-2022, 08:31 AM   #9
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Nice setup!
Old 05-05-2022, 01:16 PM   #10
Smokin19
Thanks
Wish I knew how to upload a video file without putting it on YouTube or I would. Has a muscular crackle and it barks pretty loud when you get on it. What I didn't expect was to hear that much more whine from the blower being ported, WeaponX lid and the big gulp.
I also didn't expect to have that much gain with the stock heads. I have no plans at this time to change anything.
Old 05-05-2022, 01:28 PM   #11
IneedAZ
IneedAZ's Avatar
What do u call dramatic? When i did my build a few years ago, most were reporting 25-35rwhp gain for the $2k investment. That is why i opted not to do them at this point. Are they getting more now as new stuff hits the market?
Old 05-05-2022, 01:33 PM   #12
Smokin19
My builders experience with ported heads said, "maybe 20 rwhp more" for $2k - $2.5k.
Old 05-05-2022, 02:12 PM   #13
KingLT1
KingLT1's Avatar
That's my understanding as well. 20-25whp. Certainly not dramatic by any means. You have to consider the source.
Old 05-05-2022, 02:36 PM   #14
JSH
JSH's Avatar
Drives: '20 ZLE
He's gained 145 hp over stock. My point was that there's an additional ~28-30% available in the heads. To me that's dramatic or considerable. I now see that the OP did not believe there would be sufficient hp/$, which is all I was asking.
2020 ZL1LE A10.
