Old 05-04-2022, 09:25 AM   #1
Martinjlm
Retired fr GM + SP Global
Martinjlm's Avatar
Any tips on removing plasti-dip.
I plasti-dipped my engine covers orange a few years ago, figuring that once I decided on what I really wanted to do with them I could remove it and pivot to a more permanent solution. Now I know what I want to do and need to remove the plasti-dip. Of course I could just peel it off, but I’m wondering if there is a chemical approach that would be faster and won’t damage the covers.
Old 05-04-2022, 10:32 AM   #2
Katech_Zach
Katech_Zach's Avatar
Drives: 14 Camaro SS 1LE
I think they sell some solvents specifically for plastidip.
I don't think i'd worry too much about "damaging" the covers, if they are getting show painted, they will heavily sand / smooth / body fill them anyways.
You may want to ask the paint shop if they can just remove it for you (assuming this is the route you are going)
Katech_Zach is offline   Reply With Quote
Old 05-04-2022, 10:57 AM   #3
If you damage them while peeling off the plastidip, I'll send you mine, they're almost new (they came off when the Maggie went on, paint on the lettering still flawless).
Old 05-04-2022, 11:44 AM   #4
BLACK21SS
Oldman w/a teenager brain
BLACK21SS's Avatar
Drives: 2022 ZL1 A10
Prep with Naptha, and let it soak in for 10 minutes. It should come off easy.
BLACK21SS is offline   Reply With Quote
Old 05-04-2022, 07:05 PM   #5
ste6000
ste6000's Avatar
Drives: 2018 Camaro SS
this is what i used for my wheels, turns it to liquid and then you just wash it off.
https://www.dipyourcar.com/collectio...31141798150227
2018 Camaro SS - Hyper Metallic Blue
ste6000 is offline   Reply With Quote
Old 05-11-2022, 02:58 PM   #6
infinitereality
Limitless Imagination
infinitereality's Avatar
Drives: 2018 ZL1 & 2022 Hayabusa
Goo Gone plus a pressure washer is your friend to remove it. You can buy DYC brand, but several years ago people said it's rebottled Goo Gone basically, even same orange color.
The main reason I posted is for a PSA, I do NOT recommend doing any vehicle in plastidip. They say it's harmless, etc, but it absolutely is not harmless. On the 4th of my old Hayabusa this happened to my stock paint. Of course I contacted them, which was no help other than giving me a little credit for their site........which does nothing when their product directly messed up my paint. I did use the said credit for more dip because I couldn't afford a paint job. Still had to spend a couple hours sanding all these crinkles it caused so I'd have a smooth surface again. I picked up a '22 busa few months ago and absolutely will not dip it or any vehicle ever again.
2018 Camaro ZL1 - Black
- OEM Options: A10, Exposed Carbon, PVR, Nav, No Sunroof
- Lightly Tinted GM Dark Tails, DD Side Markers, Morimoto 5000k, 100% LED
- RotoFab Dry, Forgestar CF5V (ZLE Spec), Eibach Pro, AeroForce Interceptor, GT4 Tow Hook
- Carbon Fiber (Satin): Radio, Shifter, Steering Wheel Controls, Shifter Top, AC Vents, Side Mirrors & Shark Fin
2022 Suzuki Hayabusa - Brilliant White Pearl & Shocker Yellow Wheels
- +4 Arm, 240 OEM Wheel, Brock's CT (Ti) Exhaust, 1.25" drop, etc...
infinitereality is offline   Reply With Quote
Old 05-11-2022, 09:19 PM   #7
Martinjlm
Martinjlm's Avatar
Thanks everybody for the tips. I have resolved my issue thanks to arpad_m who still had his original covers in flawless condition. I’ve left the thread open so that others can benefit from the knowledgeable tips that you guys are dropping in.
James
