Old 04-30-2022, 10:06 PM   #1
Motor Fast
Drives: 2018 Camaro SS 1LE
Idle Video: 2002 Camaro SS Getting a Katech 416ci and More
I've had this car since 2004 and used it many years for a daily. I knew at some point I would do a full build and that time has come. It's getting a full powertrain upgrade along with many other items, not much is going to be left untouched. Due to the slow supply chain right now it's going to take some time but it should be fully completed by late August or September. Updates will be posted but here's the starter:
2002 Camaro SS | 2003 Corvette Z06 | 2008 Corvette | 2012 Corvette ZR1 Inferno Orange with PDE | 2016 Corvette Z06 C7.R | 2018 Yenko Camaro
Motor Fast is offline   Reply With Quote
Old 05-05-2022, 04:27 PM   #2
Katech_Mike
Drives: 2015 Camaro ZL1
Super excited to start this build!
Katech_Mike is offline   Reply With Quote
Old 06-15-2022, 12:28 PM   #3
NW-99SS
Drives: 1999 Camaro SS M6 - SBE LS1
Stuff of dreams! Would love to have Katech build my 99. Common lottery!
1999 Camaro SS 6M - SBE LS1
1994 Camaro Z28 6M - Golen 383 HT
1963 Corvette GrandSport - ZZ502 4M
2017 Denali 1500 6.2
2017 Yukon Denali 6.2
NW-99SS is offline   Reply With Quote
Old 09-05-2022, 10:40 PM   #4
Motor Fast
Arrived at Katech last Friday. New built engine, transmission, rear-end, and much more.
Old 10-07-2022, 10:49 PM   #5
Motor Fast
Getting close, nearly everything is getting replaced on this car. High quality video of idle, drive around, and more coming November 24.
Old 10-11-2022, 08:47 AM   #6
NW-99SS
Make sure you get rid of that known failure pulley on the power steering pump, especially running the stock plastic reservoir.
There are kits available now to run the C6 pump with a remote reservoir. If the plastic one fails when the pulley lets go and breaks it open, a fire will start immediately.
I would also ditch the factory "power steering cooler" - it does nothing to lower power steering temps. Replace with a straight hose from a non-cooler car, and if you want cooler power steering, install an actual small cooler radiator and plumb the lines to and from the pump.
Anyway, awesome build, just some pointers I've learned with my 4th gen over the last 22 years.
Old 10-15-2022, 01:44 PM   #7
Motor Fast
Thanks, I'll have to look at the power steering pump option. My goal was to replace every part but some things I couldn't find. The steering system and starter were the main items.
Old 10-15-2022, 01:48 PM   #8
Motor Fast
Numbers from the engine dyno a couple weeks ago:
Old 10-17-2022, 09:02 AM   #9
NW-99SS
Nice numbers! 500+ TQ from 3500 and up is strong.
Old 03-24-2023, 12:22 AM   #10
Motor Fast
Got it back and took a short idle clip, another video will come shortly.
