Old 04-30-2022, 07:59 AM   #1
v8
v8's Avatar
Drives: 19 Z06
Did we just find the best catch can?
OK, so I got a bunch of mail asking about the E2-X, as the last video I did was the ultra and not a lot of people use the ultra. What I did was run the E2-X on the LT4 engine for about 300 miles, and then do the same with the MightyMouse. To save you the trouble if you don't want to watch the video the Elite did very well. I am not affiliated with any company
Gone but not forgotten:
1974 Corvette Stingray 454
1986 Z28
2009 Mustang GT convertible
2012 45th 2SS Vert
2013 ZL1 M6
2014 Zl1 M6
2014 GT500
2016 Challenger Hellcat M6
www.youtube.com/c/garageking
v8 is offline   Reply With Quote
Old 04-30-2022, 08:56 AM   #2
Z OH 6
Drives: 2024 CT5-V Blackwing
And here we go...
Old 04-30-2022, 09:24 AM   #3
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I run a standard mishimoto catch can combined with a metco valve cover breather that has a check valve disk. I removed my Whipple to install larger injectors and the supercharger was pretty clean inside after 11k miles.
Old 04-30-2022, 09:30 AM   #4
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
I’m installing an E2-X as we speak. It’s a well made piece.
CW3SF is offline   Reply With Quote
Old 04-30-2022, 09:54 AM   #5
20Bluezl1
I run the E2-X Ultra and love it no problem with and it catches oil.
Old 04-30-2022, 10:07 AM   #6
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
And here we go...
Old 04-30-2022, 11:25 AM   #7
Z OH 6
Old 04-30-2022, 11:49 AM   #8
Puddin
Que Elite to come in here and give their whole spiel on why theirs is the best.
Old 04-30-2022, 12:39 PM   #9
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Old 04-30-2022, 01:50 PM   #10
Z OH 6
Reasons why this video doesn't jive with my own testing results. I had my Mighty Mouse Wild on my car for 3k miles before I pulled the blower lid and checked mine, there were no pools of oil residue in my blower anywhere, and this is on a 700whp ZL1, it was pretty much bone dry as far as I could tell.
Old 04-30-2022, 06:18 PM   #11
hawk02
Coupe Newbie
hawk02's Avatar
Exactly. And if you install their catch can, there will be riches waiting for you at the end of a rainbow.
Old 04-30-2022, 07:14 PM   #12
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Wait …. They told me i would get 72 virgins aT the end of the rainbow.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 04-30-2022, 07:41 PM   #13
v8
v8's Avatar
Drives: 19 Z06
So you had different results then. I am surprised at your results as running the wild set up bypasses the factory separator under the blower, so pretty much your only separation is the can. With running the regular set up with any can you use the can plus the factory set up under the blower. I would never recommend bypassing the factory separator as that's an important feature.
I'm not affiliated with either company, and received no compensation from the company. I did purchase both catch cans, and was surprised at the results. I did contemplate for quite a while about even posting it, as I don't want to make anyone look bad, but the results are what they are.
You are lucky if you are filtering that well, but I suspect most likely you are just venting everything out, factory vehicles will never produce the pressures that your 700whp produces, and thus will rarely vent, so they will be forced to recirculate the air and filter as best they can.
1986 Z28
2012 45th 2SS Vert
2013 ZL1 M6
2014 Zl1 M6
2014 GT500
Old 04-30-2022, 07:41 PM   #14
AZIROC
Drives: '86 IROC-Z '18 ZL1
Male virgins.
catch can, elite engineering catch can, mightymouse
