Old 04-29-2022, 10:03 AM   #1
Julian1le
Drives: 2020 camaro ss 1le
Before I get another 1le. Questions!!
I’ve noticed the rocker panels get sprayed like crazy with rocks and dirt. Causing unsightly chips and paint damage.
My question is , how can one avoid that? I’ve noticed my neighbors RS 2018 Camaro doesn’t suffer from this.
Are the wider front rims which cause the tire to stick out a lil causing this or is it the Goodyear sticky tires kicking up rocks? Would all season tires not kick up anything!?
Rock guards don’t stop every rock and PPF would require covering the whole side of the car. Just wondering if there’s a way to solve this problem.
Julian1le is offline   Reply With Quote
Old 04-29-2022, 10:20 AM   #2
Twizzty
Twizzty's Avatar
Drives: 2021 Camaro 1SS 1LE
I'm with you on the rock guards not being enough for the 1LE, I have them and still hear lots of rocks bouncing down the side of my car. It's a combination of the wider front wheels/tires and sticky tires IMO.
I've had several people tell me it's better with side skirts installed as it blocks more of the rocks but I haven't tried it yet, personally I like the look without them.
2016 Focus RS MT - Sold
2018 Mustang GT A10 - Sold
2021 Camaro 1SS 1LE MT
2023 CX-50 Meridian Turbo
2023 KTM Duke 890 GP
Twizzty is offline   Reply With Quote
Old 04-29-2022, 10:50 AM   #3
VR Baron
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE
I use guards and PPF. The PPF only needs to be the lower part of the doors up to the centerline of the” door bulge” for the door. I did the front and fenders, and of course the worst area, the area in front of the rear tire to the body line gap. Rear guards protect behind the rear wheel, or PPF
VR Baron is offline   Reply With Quote
Old 04-29-2022, 12:44 PM   #4
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
Side skirts do help a lot, but you'll also want some PPF in front of rear tires + rock guards
Old 04-29-2022, 01:22 PM   #5
ZPirate
ZPirate's Avatar
It's a combination of the wider wheels and stickier tires that causes the problem. Even if you switched to less sticky tires the wheels are so wide that they are still going to kick up stuff on the road. I think a good set of rock guards and side skirts will prevent most rock chips. You could also add some PPF for more protection. And not all rock guards are created equally. You need ones that offer the most protection.
I have ACS Composite rock guards and side skirts on my 1LE. The match the satin black trim pieces on the 1LE too. So far they seem to be doing a good job of protecting the paint. I can still hear stuff hitting the bottom of the side skirts on occasion, so they must be doing something. I also have PPF, but just on the front of the car and the mirrors.
2003 Nissan 350Z (modified)
2009 BMW 135i (Sold)
Old 04-29-2022, 01:28 PM   #6
Nothing like an SS
Faster!!!
Nothing like an SS's Avatar
Drives: 2020 Camaro 1SS 1LE
I do not have guards, but I do have skirts, and I have very little issue so far @ 5200 miles. Skirts must be doing something! I also hear the rocks hitting the skirts, SOUNDS like the side of the car, but it isn't, at least not causing any chipping. Not zero mind you, but just a couple of spots on each side.
From the horror stories on here, I'd say they are effective.
Skirts were installed at about 600 miles
Nothing like an SS is offline   Reply With Quote
Old 04-29-2022, 01:28 PM   #7
78yellow78
Drives: 2017 Camaro SS 1LE
My winter tires on skinny wheels kick up nothing. As soon as I put the summers on I cringe hearing all the crap hit the paint. I do have the color matching GM rock guards. I have a good body shop in town and figure I will just get the pain touched up every now and again.
78yellow78 is offline   Reply With Quote
Old 04-29-2022, 04:38 PM   #8
Chrome383Z
Chrome383Z's Avatar
Drives: 2019 Camaro 2SS
Guards, skirts, and PPF will definitely help.
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
Chrome383Z is offline   Reply With Quote
