Old 04-28-2022, 04:37 PM   #1
f.d
Drives: camaro
TPS
Please question:
SS Automatic 2018
1- In WOT why TPS give max round 84% why it’s not 100% in WOT (HP tuners)
2- Is this the same in manual SS +16 or it gives a bigger number for TPS.
f.d is offline   Reply With Quote
Old 04-28-2022, 05:13 PM   #2
Trochoidal
Drives: 2017 Camaro 2SS A8
Here f.d this might help you and I do believe this is the same for the manual cars.
https://www.camaro6.com/forums/showthread.php?t=561854
Old 04-28-2022, 05:15 PM   #3
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
Because as much as you think you are in control of the throttle blade with your foot on the accelerator - you are not. The ECU commands the throttle blade based on multiple factors. Your foot is just one of those. These cars have a lot of torque management in place.
476 rwhp/440 rwtq (sold)
Old 04-28-2022, 10:22 PM   #4
It's weird indeed, but doesn't matter in the grand scheme of things. As SSDan pointed out, the ECU knows you're flooring it and will command an appropriate blade angle taking whatever pedal percentage you see at that point as WOT.
Old 04-29-2022, 03:09 AM   #5
f.d
Drives: camaro
Thanks for you all.
The weird thing is: I see with manual transmission TPS 96%
Any way the car pull awesome, and I just want to know more.
Thanks
Old 04-29-2022, 11:21 AM   #6
wnta1ss
Drives: 2017 Camaro 1SS
My 2017 at WOT shows 99.6% for Throttle Position (not the SAE one). I also log Commanded Throttle Actuator (SAE) and that one reads 100% for me at WOT. For what my foot is doing, I log Accelerator Pedal Position (not an SAE one) and that reads 99.6% at WOT.
Old 04-29-2022, 06:14 PM   #7
f.d
Drives: camaro
Thanks for the reply
You have manual transmission! Yes?
Old 05-01-2022, 04:23 AM   #8
wnta1ss
Nope, my 2017 SS has the A8. Plus I've logged a 2016 SS A8, and these 3 channels gave the same readings at WOT as mine does.
