Old 04-28-2022, 12:31 PM   #1
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Edelbrock Lid spacer order for zl1 or SS.
https://www.camaro6.com/forums/showthread.php?t=604850
I'm getting a quote for a 1 inch lid spacer for the Edelbrock 2650 for another member just seeing if there is anyone else is interested so I can cut some all at once. I had a local company cut me some close to 3 years ago and they work perfectly. I wish Matt would of did a before and after test but he's so busy.
I don't know anyone making 1004 on mustang or 1044 on hub dyno with a 8.3 lower and 3 inch upper. The kong porting, 112mm TB, and lid spacer probably all contribute to that.. I set this up to be the most efficient way possible.
On a camaro SS you probably have enough room with no cutting the hood but don't quote me. I figure since my wife runs the 2300 edl. and the stock tower brace which sticks up quite a bit, there's room.
ZL1's with the LPE insert can run up to a 5/8 for sure and 3/4 will have slight rub on the LPE insert if the insert if it has fallen a tad but if its held up tight the 3/4 fits. 1 inch will fit no problem if you use a heat gun an remove the glued on plastic brace for the metal cover which has to be mod'd anyhow but no carbon insert can be used for 1 inch to fit.
Material: Plate 6061-T6 Alum water jet cut
Old 04-28-2022, 01:33 PM   #2
AZIROC
Drives: '86 IROC-Z '18 ZL1
So is this the spacer alone or the lid and spacer?
Old 04-28-2022, 01:35 PM   #3
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
It's 1 inch spacer that goes between the lid and blower body or you can request what ever thickness.
Old 04-28-2022, 10:25 PM   #4
Ron_Robinson1
Ron_Robinson1's Avatar
Drives: A Static line to a pack tray & ZL1
Send a message via AIM to Ron_Robinson1
You think the 1” spacer will make much more of difference over the 5/8 I’m currently running.
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4)
SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129
SOLD-2011 SS M6: Blower, Cam, Alky, LTs.
Ron_Robinson1 is offline   Reply With Quote
Old 04-29-2022, 06:41 AM   #5
Z OH 6
Drives: 2024 CT5-V Blackwing
What's the purpose?
Z OH 6 is online now   Reply With Quote
Old 04-29-2022, 07:08 AM   #6
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
What's the purpose?
I know a taller lid kept the z06 from overheating at the track.. you can raise the height by building a new lid or the cheaper way a spacer.
And there's this..
https://youtu.be/i8zkZmDXYCE
It's a ls but same principle..
Old 04-29-2022, 07:11 AM   #7
Z OH 6
And there's this..
Yea, it helped the 2015-2016 Z06 because there was almost no space inside. Does the Edelbrock have this issue too?
Old 04-29-2022, 07:15 AM   #8
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
I would say all 2650s could benefit since they try and fit it under a zl1 hood.
Seeing how the truck lid is way taller and advertises more power than the ss I think there is something to be said.
In my case I think it's beneficial I'm moving a lot of air so the volume would help.
Old 04-29-2022, 09:37 AM   #9
gotswap
gotswap's Avatar
Drives: 2019 ZL1 Crush
Have them make the port injection plates and I am in
2019 Crush A10
E-Force 2650
670WHP 615WTQ
All besides the 2650 is bone stock down to the air filter.
gotswap is offline   Reply With Quote
Old 04-29-2022, 11:49 AM   #10
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Give me a cad file and make it happen
