04-27-2022, 05:11 PM | #1 |
Drives: 1LE Join Date: Sep 2017
Freshened LT1 Longblock F/S
I dont hang on the section of this forum but can ask for my credentials over on the "road racing section" if you'd like.
pics and more here https://www.facebook.com/marketplace...7321180416865/ Condition Used - like new FOR SALE 5TH GEN LT1 LONG BLOCK JUST REFRESHENED AND NO RUN TIME. THIS ENGINE WAS MY “SPARE” FOR MY 2017 CAMARO 1LE ROADRACE CAR. I HAVE ALL RECEIPTS. ALL READY JUST NEEDS YOUR ENGINE COVERS! - Manley 2618 Pistons in 11.7:1 compression -Manley H-Beam Rods - ARP Rod Bolts -Wet sump GM LT1 crankshaft -Texas Speed 229/244 .635/.635 112 LSA 109 ICL + 32% fuel lobe -2116LSR - Johnson Lifters Link Bar -97-TVS-2187P - PAC POLISHED .660 Dual -Chromemoly Pushrods 3/8-Diameter -212-CHETrunion - CHE LS/LT Trunion Kit - 0 Degree Phaser Limiter -DOD Delete Kit -HD C7R Timing Chain by IWIS -GM factory oil pump -GM MLS Head gaskets WORK PREFORMED ON REFRESHED SHORT BLOCK Disassemble Short Block Degrease block, crank, rods Degrease miscellaneous engine parts. Measure Main Bearing Bores and Alignment Measure Bores Measure Crankshaft Main & Rod Journals Balance V-8, Internal TIG weld reluctor to crank Hone V-8 cylinders with plates Wash block for assy or cam bearings and plugs Install Cam Bearings Fit Cam Bearings to cam File End Gaps - 16 Piston Rings Install each Piston Ring Manley Forged Piston Total Seal AP Steel Rings King Main Bearings HP/XP Series King Rod Bearings XPN Series Cam Bearing - Coated Overhaul oil pump, check relief valve, variable vane system Install bearings, measure main & rod clearances, selective fit bearings for proper oil clearance. Assemble LT1 short block, review all dimensions & clearances LT1 CYLINDER PORTED HEADS. NO RUN TIME. -Brand new GM LT1 heads -CNC fully ported -97-TVS-2187P - PAC POLISHED .660 Dual |
