Old 04-27-2022, 10:13 AM   #1
KamZL1
KamZL1's Avatar
Drives: Z06
MAD vs. KONG
I know a majority of people go with Kong for porting but I was wondering if anyone has experience with modern airflow dynamics, how it compares to the x port. Asking because I live in Houston and probably going to do porting when I do headers/pulley in the next few months. It would be much more convenient to get it done locally than to ship off IMO. All feedback appreciated,
Thanks,
KamZL1 is offline   Reply With Quote
Old 04-27-2022, 10:30 AM   #2
Z OH 6
Drives: 2024 CT5-V Blackwing
Jokerz is another option, they also do fantastic work.
Old 04-27-2022, 11:20 AM   #3
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Something I'd been thinking about (I think Alec, from LMP said a few videos ago), that on these max effort combinations, it really pushes these little blowers to a (possible) reliability point. I understand a 900-WHP 1740 build and longevity is different than a 700-WHP 1740 build and longevity (you obviously are going to be spinning the blower faster/harder for more air flow), but with all the material that has to be cut-out (I imagine around bearing plates and supports), how much the rotors may or may not move around in the case. I mean, the rotors probably don't wiggle much below their rated RPMs (by Eaton), but what about the bearing support just behind the snout? Or - what about the shaft-support area? Is there any real mechanical analysis done for these porting programs in these areas?Maybe it doesn't even matter.
Just thinking out loud...
I don't know if there's really an appreciable difference, at this level of porting, from anyone listed so far. I've read and watched great results from all of them. Had I gone a different path, I'd probably gone with any of those guys. While not as convenient, I've heard Synergy does good porting, too.
'20 ZL1 Black "Fury"
Old 04-27-2022, 01:13 PM   #4
Raisin Man
Drives: Chevrolet Camaro
Thanks,
Why don’t you check out Katech? I know nothing about Kong, but Katech has actually built quite a few engines that have won in both IMSA & Trans Am competition. The other guys, not so much. Might pay a bit more for the quality reliability.
Raisin Man is offline   Reply With Quote
Old 04-27-2022, 01:21 PM   #5
Z OH 6
Nothing wrong with Katech but the others mentioned here also have very good reputations.
Old 04-27-2022, 03:26 PM   #6
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
I would agree regarding those who pulley and spin them harder. That’s why my build is stock pulleys. I don’t think it’s a good idea to spin the 1.7 harder.
CW3SF is offline   Reply With Quote
Old 04-27-2022, 03:38 PM   #7
JSH
JSH's Avatar
Drives: '20 ZLE
HPE increased rpms by going to a 10% lower, and CAP decreased rpm by going to a 2.40" [or 2.45"?] upper, so, in summary, mine is probably spinning a little faster than stock.
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 04-27-2022, 03:43 PM   #8
ZapperZ
Drives: 2018 ZL1 1LE 2022 GMC AT4 HD
Really like Kong CNC
103mm throttle body,Big Gulp,2"headers,AWE exhaust and a good tune
Excellent formula for a track car
NO pulley change
ZapperZ is offline   Reply With Quote
Old 04-27-2022, 04:25 PM   #9
KamZL1
KamZL1's Avatar
Drives: Z06
NO pulley change
yeah this is what I want to do but a pulley as well because more than likely it will never see a track. also I think standard rf is fine until you really start getting up there..
Old 04-27-2022, 04:32 PM   #10
Katech_Zach
Katech_Zach's Avatar
Drives: 14 Camaro SS 1LE
Depends on your combination. We have had good results with a few blower porters including our own. It all depends on your combination. A max effort port is meant to be spun to death, you wont utilize its additional airflow unless you death spin it. A generic ported blower works well with relatively stock or mild modifications. Max effort ports may even hurt mildly modified cars until you add a giant cam, "death pulleys", etc.
Same thing with any part of the engine (using a giant cam with tiny heads, large port heads with a tiny cam, etc). You need to think about the combination, and not just the blower.
Katech_Zach is offline   Reply With Quote
Old 04-27-2022, 05:23 PM   #11
Z OH 6
Basically what I was told by Vengeance Racing as well when asking about the Kong X port.
Old 04-28-2022, 08:10 AM   #12
KamZL1
KamZL1's Avatar
Drives: Z06
really so x port really isn't worth until you address fueling in a serious way (dsx & cam/injectors) better off getting standard port for headers/pulley staying at or under 700?
Old 04-28-2022, 10:34 AM   #13
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Late Model Performance's Kong X-Port on a completely stock CT5-V:
Complete Street Performance's standard Kong Port on a ZL1 that had a tune and then added/tuned for the blower:
It might depend on what you think is good value. Maybe another 10-15-WHP is worth $500 to some - maybe not.
Old 04-28-2022, 01:31 PM   #14
AZIROC
Drives: '86 IROC-Z '18 ZL1
+1 when I just called Kong. I'm not looking to do a max effort build, just basic bolt ons ( no cam/heads) but was going to do a pulley. They said a reg port would be fine but an x port wouldn't be worth it as im not trying to spin the blower that hard.
