Old 04-21-2022, 12:23 PM   #1
American thunda
Drives: 2021 Lt1 Camaro
Just ordered my Procharger! Now what?
Hey guys kinda been lurking on the forum for a while. Well I just took the plunge and ordered my kit. I ordered the P1x with the stage 2 IC. I plan on running this car on a Meth kit. Thinking about going with a Snow kit. I would like not to do any other fueling mods at this time. My question is what else will I need? Im getting a wideband, Dsx baro break out,colder plugs,colder t stat and Headers. What am I missing? Im gonna be tuning this as well. Thanks
American thunda is offline   Reply With Quote
Old 04-21-2022, 02:27 PM   #2
LT1ornothing
Drives: 2020 LT1 M6
If/when the meth system fails, your engine will be destroyed. There is uneven meth distribution issues as well, cylinder #7 seems to go out on meth dependant set ups. You may want to consider upgrading to at least an LT4 fuel system and skipping the meth or do both. Most blown up supercharged LT1 engines happen because the owner failed to upgrade the fuel system for the increased fuel demands AND octane demands.
Old 04-21-2022, 03:08 PM   #3
I agree with 1LEornothing, this adds a continuous high risk component when you can achieve very good results with a properly upgraded fuel system, injectors and/or ethanol.
Not sure why you would want to skimp on the most fundamental component of a reliable build ("I would like not to do any other fueling mods at this time").
Old 04-21-2022, 04:32 PM   #4
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
I'd advise the OP to do a bunch of reading on this board about forced induction LT1s and fueling...and lack of octane...
Old 04-21-2022, 09:29 PM   #5
cjperformance
cjperformance's Avatar
Order your new pistons now.
Kidding aside... fueling install was pretty easy to do dsx and lt4 high side. LMK if you have any questions.
DSX Aux Low Side | LT4 high side | Flex Fuel
TooHighPsi Port Injection (installed & tuning)
CircleD 3K Stall | QA1 CF Driveshaft
Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear
Forgestar F14 18x8 NT555G2 235/50/18 Front
10.84@131 w/4.13" pulley
??.??@??? w/3.7" pulley (installed & tuning)
Old 04-22-2022, 12:11 AM   #6
American thunda
I’m going this route. I really like the looks of the dsx kit. Thanks.
Old 04-22-2022, 09:11 PM   #7
MSU120
Drives: 2018 1SS 1LE
I good luck and Enjoy! You won’t regret going with the PC.
2018 SS 1LE—707rwhp, 615rwtq
2009 Pontiac G8 GT—605rwhp, SOLD
MSU120 is offline   Reply With Quote
Old 04-23-2022, 11:13 AM   #8
JANNETTYRACING
JANNETTYRACING's Avatar
These are the components you will need, all OEM fuel system parts except for the voltage booster which every forced induction car should have
https://jannettyracing.com/products/...2018-camaro-ss
Also will need this https://jannettyracing.com/products/...ness-for-gen-v
And this https://jannettyracing.com/products/...bar-map-sensor
And these https://jannettyracing.com/products/...s-heat-range-6
Then a quality custom tune here https://jannettyracing.com/products/...cadillac-cts-v
Any questions call 203-753-7223
Ted.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 04-23-2022, 10:30 PM   #9
American thunda
Ted.
Thank you ! This helps so much!
Old 04-23-2022, 10:31 PM   #10
95 imp
Dumb Ass Deluxe
...I plan on running this car on a Meth kit....
...I would like not to do any other fueling mods at this time. My question is what else will I need?
Pistons and/or a new block.
Old 04-24-2022, 09:01 AM   #11
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I would advise purchasing new high pressure fuel lines when if you change injectors and HPFP. Get the LT4 inlet and outlet feed lines. Doesn't hurt to change the cross over line too.
