![]() Drives: 17 hyper blue 2SS M6 Join Date: Mar 2018
SRS airbag light fix after race seat install
I figured I'd finally put all my information into one spot on how I went about getting around the airbag light after I installed my race seats.
First I feel like I must say this is only what I have done, and what I was comfortable doing. My goal was to keep the warning lights off, and maintain the factory seat belts along with the 6 point harnesses. I also have a 2SS with memory functions. I bought the entire wiring harnesses for both seats, part numbers are 84280991 for the driver's side and 84280995 for the passenger. I bought 2 airbag resistors online at this site, https://www.automotivecircuitsolutio...iagnostic-tool . You'll also need to remove several things from your stock seats or order new to install. The module under the driver's seat is important if you want to maintain the use of your mirrors. You'll also need the passenger seat position sensor (22886642) and the passenger seat occupancy sensor (84139855 for a 2017, 84603169 for 20/21). I chose to take all these from my seats before I sold them. I installed the harnesses, plugging in the stock belts including the pretensioners and all the sensors and module. After confirming it all worked, I removed the harnesses amd cut off all the extra pigtails from the harness to save some space. One thing to note on how I did mine was I only took the electrical switch for the occupancy sensor, not the mat that has fluid in it to actually actuate the switch (I didn't want to tear apart the seat bottom). So in my case my car does not believe anyone is in the passenger seat. My car sees about 99% track duty, so I'm comfortable with how the system will function. Hope this helps. Last edited by Baddawg53; 04-20-2022 at 07:23 PM. |
I did the same thing when i put a BRIDE seat in my 370z.
It was not nearly as complicated however. Good write up And thank you for the links. Keep us posted!
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8 Results: 470 hp / 447 tq |
#3 | |
![]() ![]() ![]() ![]() Drives: 2019 Camaro Z-28 Join Date: Jul 2010
I had planned on NOT using anything off my STOCK seats but as you also know, you are probably looking at spending over 1K for sensors if you buy them from GM. I am like you in that I have a SS2 with all the memory functions and things like heated seats so this conversion is more difficult than if you had an SS1 for instance.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
That's a great idea getting pictures of the locations. That'll definitely help as I remember not knowing what any of those switches looked like. In the next couple weeks I'll get an ohm reading on those resistors, good information to have.
![]() Drives: 2021 ZL1 1LE Join Date: Dec 2017
I've been working thru racing seat install. I'm OCD and don't want to see the airbag light. This is a great write up and was a basis for my approach. I bought new seat wiring harnesses as well as a new memory module for driver seat. Also picked up the airbag simulator resistors. I have a used passenger seat bottom on the way to pull the presence sensor and seat position sensor out of. My goal is to keep stock recaros 100% in tact to be able to swap back and forth as desired.
I stripped down the wiring harnesses and eliminated any unnecessary wiring/connectors, drastically reducing the amount of wiring I'm securing under the seats. I finished the driver seat and wanted to test it before finalizing the passenger figuring I can identify an issues before changing two variables (seats) and potentially not knowing which one was causing any issues. After install of the driver seat I didn't get an airbag warning or light. I was stoked! But then I tried adjusting my mirrors and they didn't work... Does anyone know if the memory modules are plug and play or if they require dealer involvement to allow them to operate properly? |
Interesting question, sure seems like they're probably programmed to each vehicle if yours doesn't work.
It's a fairly easy swap out though, if you wanted to make it work until you can get the new module programmed. |
#7 |
Instagram: Sangstah
I used these guys for my bride seat in my 5th gen, worked great and plug and play.
http://airbagsystems.com/simulator.html |
#8 | |
![]() ![]() ![]() Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
#9 | |
This is why I bought a new memory module and am frustrated that I went thru the cost hassle only to find out the mirrors done work. It's really not that big of a deal as I'm the only one who drives/tracks it so I can set them ans not worry about it, but I'd like to be able to adjust with controls if I need/want to. |
#10 | |
#11 | |
If I'm understanding, you have a racing seat installed with no harness, and you have an airbag light but your mirrors still work. For my personal approach: I have a Brey Krause seat mount which allowed me to install factory seatbelt components. I bought the seat wiring harness and stripped it down to just the connectors for receiver buckle, pretensioner, seat side airbag and the memory module. I bought the airbag resistors in the OP's link (one needed per seat). Plugged in the resistor and connected the seat belt connectors and memory module. No airbag light. Don't know if you need to connect the seat belt components but I didn't want to solve the airbag light issue only to end up with a seatbelt light... |
#12 | |
#13 | |
![]() Drives: 2021 SS 1LE Join Date: Mar 2023
#14 |
![]() Drives: 2022 1ss/1le Join Date: Mar 2022
