L8ap3x
Oil change based on time, not mileage
18 2SS 25k miles
Last oil change was Nov2020 before winter storage. Driven 3k miles last summer (blasphemy to only drive a Camaro 3k miles). Now she's re-emerging from winter and my plan was to change the oil before my next track day in June but based on the above, should I do a routine 5-30 change based on time alone? Thanks |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Mazda6, 2011 Mustang 5.0 Join Date: Mar 2010
I've always felt that oil should be changed at least once a year regardless of mileage. I could be wrong, but I've always believed that when it's out of the bottle and exposed to the air, it degrades just sitting...somewhat like gas going stale if it sits too long.
Many oil life monitors will indicate the same. Not sure what the Camaros algorithm does, but the monitor on my Mustang diminishes 2% every week whether it is driven at all or not. Ultimately, oil is cheap and easy to change. Engines are not. Much better to error on the safe side.
2022 1SS 1LE (Arrived 4/29/22)
"The car is the closest thing we will ever create to something that is alive." |
L8ap3x
Ultimately, oil is cheap and easy to change. Engines are not. Much better to error on the safe side.[/QUOTE]
Fair point. Thanks for confirming. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Camaro 2SS Hyper Blue Metallic Join Date: May 2020
I don't put enough miles on any of my vehicles to warrant an oil change during the year, so I always change my oil once a year.
#5 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2023 Summit White Camaro ZL1 M6 Join Date: Dec 2021
2023 Dodge Durango SRT (daily driver) 2003 Nissan 350Z (modified) 2022 Rapid Blue 1SS 1LE M6 (delivered 2/19/22) (Sold) 2009 BMW 135i (Sold) |
Hot Camaro
Your car will tell you when to change, and it will be based on a combination of mileage and time. Max time interval is one year regardless of mileage.
My car had an oil change done in something like September of 2020 and then went into storage. It came out in May of 2021 and was basically saying that I needed to change the oil "soon" even though I only put a few hundred miles on the car between the last oil change and going into storage. |
#7 | |
One caveat regarding the oil life monitor. It may be programmed to tell you to change every year, but if the battery is disconnected during storage, the monitor's clock will be stopped and behind however long it was disconnected.
#8 |
Hot Camaro
Are you sure? Wouldn't the minder write the datestamp of when it was last zeroed out and then compare that against today's date once the battery were put back?
#9 |
![]() ![]() Drives: 2017 2SS Arctic blue fully loaded Join Date: Mar 2021
it's so easy to change the oil and filter on our cars it's madness not to change it once a year or when the service warning tells you.
#10 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
I want to know where you go to change your oil. Because my oil changes range from $120-$160/pop with a 10 Qt system, my 2016 camaro oil change ran me 70-$90 back in 2018/2019. Sometimes I wish I was mechanically inclined.... :(
#11 | |
Hot Camaro
For street use, you can run 5W-30 dexos1 or 0W-40 dexos2 oil. The latter is a fair amount more expensive as you can basically only get it as Mobil 1 and you'll pay around $10/quart for it. The 5W-30 dexos1 oil is more widely available and can be considerably cheaper. As an example, I change my own oil with the Kirkland 5W-30 dexos1 oil. I try to buy it on sale at $25 for two 5 quart jugs which is perfect for one oil change on the car. The oil filter will cost me about an additional $10 for a Mobil 1 oil filter. If I do the full oil change myself, it costs me about $40 with all taxes and such. Or, I could take that to my independent mechanic and he would charge me $75 labor to do the oil change using my supplies ($115 total). |
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Camaro 1LT Join Date: Jan 2016
Aren't you supposed to change the oil between "Track days" anyway? Like you should do it after a track day unless your track day is really relaxed.
#13 |
Drives: 2022 ZL1 M6/Nissan Leaf Join Date: May 2016
I never really worried so much about the oil as I did the filter. I can't imagine any type of paper substance retaining its effectiveness after several months of being soaked, much less being soaked with oil.
#14 |
![]() Drives: 2016 Camaro Join Date: Oct 2017
I change my oil roughly twice a year or every 6,000 miles when I rotate the tires.
The filter gets changed with the oil, and I'm not too worried about the construction of the oil filter. Diesel fuel filters also have paper elements. However, the concern with paper in diesel is that it might freeze. Thus, the more expensive stainless-steel mesh is the choice. Texas has very few freezing days.
2024 Chevrolet 3500HD Z71, LTZ, 4x4, 6.6 ltr. L5P long-bed.
2016 Camaro 2SS Six-speed, Hotchkis sway bars, Eibach .750" drop springs, Mamo throttle body, E85, BMR stuff. 2006 Quicksilver 6-speed GTO ERL LS3-430, All-Pro 285cc heads, 262/273 .758/.742 116+3 cam, Sheet-metal Intake, 70lb Siemens injectors, SLP, GMM Ripshifter, QA1 Coil-overs front and rear, nylon suspension bushings, Hotchkis, RPM Trans, SPEC twin clutch, SpinTech, Kooks 1 7/8 -2.0", BMR drive train, Kaaz 3.91, Lingenfelter CAI, Baer brakes, mini-tubs, E85. |
