BanHamWatch
Drives: 21 ZL1 1LE Join Date: Jan 2021
Daytime running lights Canada
Does anyone know if DRL function can be changed in my ZLE I’m up here in shitty Canada and want the headlights to not be used as the DRL. With my dodge products a simple device called Tazer allowed me to change the country code to US and then I can shut them off as well as many other useful things.
Ram dealers can do it as well at the stealership. Thank you in advance
2021 ZL1 1LE
Auto |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
I guess it depends on if it's a software difference or wiring difference.
If it's software then I would assume you could ask the dealer? I do have some knowledge on how that could possibly be achieved on Ford's, since I played around with Forscan with my Mazda's(thanks to Ford owning a major part of Mazda for a good while), but not sure if there is a tool like that for GM vehicles. If it's a wiring difference then you need to do some hardware changes, but modern cars should all have DRL software-based. I remember driving a rental Corolla in the States and it even has an option in the infotainment to turn the DRL on and off.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
![]() Drives: 2021 Chevrolet Camaro ZL1 Join Date: Apr 2021
Technically illegal to turn it off in Canada so few dealers would do it officially. Maybe off duty one could / would.
I thought the DRL only turned on the LED strip lights under the headlights however.
2021 Camaro ZL1
ADM S/C Expansion Tank Dual Aeroforce gauges Eibach Pro Lowering Kit Oracle Side markers (Paint matched) Rear window "wind screen" Xpel Paint Protection Ceramic Pro Coating |
