Old 04-12-2022, 04:05 PM   #1
Osbornsm
Drives: 2018 SS 1LE
Question How much camber here?
This is a rear tire.
Notice the outside is wearing FAR faster than the inside. Not just the shoulder, but the whole outer section of tire.
I've rotated sides for this tire also.
Current Camber
-3.0 front
-2.0 rear
How much additional rear camber would be recommended here?
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si
Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8
Results: 470 hp / 447 tq
Osbornsm is offline   Reply With Quote
Old 04-12-2022, 05:31 PM   #2
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
needs more i run -2.5
Old 04-12-2022, 05:40 PM   #3
FrostZ
FrostZ's Avatar
Drives: 2019 A10 ZL1
What do you have for toe in the rear? The eccentrics for the toe adjustment are known to slip and cause a lot of wear. This has been documented to happen to a lot of owners, including myself. You already have a fair amount of camber in place that many others have used with no issues. You may want to have an alignment done to check the toe as it's a common culprit for that type of wear.
Morimoto Headlights, AWE Touring Catback, MM Catch Can, ADM V2 Reservoir, Roto-Fab, C&R Oil Cooler, 1LE Grills
FrostZ is offline   Reply With Quote
Old 04-12-2022, 05:59 PM   #4
5.M0NSTER
5.M0NSTER's Avatar
Drives: 2018 Camaro 1SS 1LE
I have -2 front and -1.5 rear my wear is much more even with 3 track days and about 3k street miles on the tires. How many track days and street miles do you have on this tire?
5.M0NSTER is offline   Reply With Quote
Old 04-12-2022, 06:08 PM   #5
khcoaching
khcoaching's Avatar
Drives: 2021 1SS 1LE
When I was at -2, it was about like that. I'm at -2.5 now and there was a significant difference with rear tire wear with that change.
Ken
khcoaching is offline   Reply With Quote
Old 04-13-2022, 09:50 AM   #6
Osbornsm
Drives: 2018 SS 1LE
Question
What do you run in the Front then?
Old 04-13-2022, 09:51 AM   #7
Osbornsm
Drives: 2018 SS 1LE
Question
4 track days, driving to the track is the miles. So maybe a thousand miles off track.
I see you're Michigan! Do you have a Gingerman Lap time?
Old 04-13-2022, 09:52 AM   #8
Osbornsm
Drives: 2018 SS 1LE
Thank you and you are correct!! The first suspension part i bought was the Rear Toe arms from SPL w/ lockouts.
I'm having an alignment on Friday, but donno what to add to the rear.
Old 04-13-2022, 10:44 AM   #9
JSH
JSH's Avatar
Drives: '20 ZLE
On a related topic, how much camber for a ZL1 setup to drag? What is the stock camber?
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO.
15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR.
100 octane: 1045hp/1055tq.
100 octane + Alky MAF Meth (1) 10+:
Old 04-13-2022, 10:58 AM   #10
Osbornsm
Drives: 2018 SS 1LE
Hey FOCUS here.
Get your own Thread JSH.
Old 04-13-2022, 11:41 AM   #11
kropscamaro16
-3.5 F -2.5 R
Old 04-13-2022, 12:43 PM   #12
FrostZ
FrostZ's Avatar
-3.5 F -2.5 R
Agreed, that's a nice jump up and with the toe arms you have eliminated the biggest unknown so an extra 0.5 all around should help.
Old 04-13-2022, 01:23 PM   #13
kropscamaro16
yup i have full spl parts kit and mcs coilovers with vorshlag camber plates but the car feels good
Old 04-13-2022, 01:41 PM   #14
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
You don't need more camber. The tread grooves are shallower on the outside of the tire, but there is still plenty of rubber.
Old Ride: 2016 Callaway SC630 Camaro SS
