Old 04-12-2022, 11:30 AM   #1
GA_ZL1
GA_ZL1
GA_ZL1's Avatar
Drives: 2023 ZL1 1LE
ZL1 Supercharger Belt Part #?
My 2018 ZL1 1LE LT4 superchrager belt is starting to fray a bit. Could someone please confirm that the GM OE replacement part # is 12668317? If so, it should be part #1 on the diagram. Second question, if I’m going to have a tech replacement the supercharger belt, would it make sense to have the other two belts (parts #2 and #3 on the diagram) also changed at the same time? My car has 25k miles on it with about 6 track days a year since I got it. TIA!
https://www.gmmidatlanticparts.com/o...Y4LWdhcw%3D%3D
GA_ZL1 is offline   Reply With Quote
Old 04-12-2022, 12:20 PM   #2
Jaxcam02
Jaxcam02's Avatar
Drives: 2017 Silverado/2017 ZL1
I always go by the replace it all together ideology. While in there you might as well do all the belts given the relative cheap price of belts.
Jaxcam02 is offline   Reply With Quote
Old 04-12-2022, 01:39 PM   #3
GA_ZL1
GA_ZL1
GA_ZL1's Avatar
Agreed, Jaxcam02! Do you or anyone else know if I've identified the correct belt part numbers? Thx!
Old 04-12-2022, 09:21 PM   #4
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
yes...double checked for you and those #s are correct. #1 is the supercharger belt, #2 is the water pump/ alternator belt, #3 is the ac belt which is a stretch fit.
Old 04-13-2022, 07:56 AM   #5
GA_ZL1
GA_ZL1
GA_ZL1's Avatar
Thanks you, Stephen12ZL1.
