Old 04-11-2022, 03:06 PM   #1
clg82
Drives: 2020 Camaro ZL1
What tires on dyno?
I just had a Magnuson 2650 installed with the California CARB tune which leaves a lot to be desired. I'm taking it in a couple of weeks to get dyno tuned at a local shop. I have the OEM tires as well as Pilot Sport 4s both on stock wheels. Which would you suggest I use on the dyno? Or does it even matter? Thanks for any help!
Old 04-11-2022, 03:24 PM   #2
Mac7504
Mac7504's Avatar
Drives: 2003 Monte Carlo SS SLP, 2022 ZL1
Nothing to offer here but can't wait to see the numbers.
I assume you will have to switch back to the carb tune come smog time?
Mac7504 is offline   Reply With Quote
Old 04-11-2022, 03:25 PM   #3
ZLAV1N
Previously CS10SS
ZLAV1N's Avatar
Drives: 2017 ZL1 A10
As long as you don't use a drag radial on a dyno, you will be fine. I would have it tuned with whatever setup you plan on using on the car. My car was dyno'd with PS4S's.
'02 Trans AM - sold
'05 SRT4 - sold
'05 STI - sold
'96 300ZX - sold
'10 2SS/RS M6 455rwhp - sold
'13 ZL1 M6 720rwhp - sold
'17 ZL1 A10 930rwhp - Katech Built
ZLAV1N is offline   Reply With Quote
Old 04-11-2022, 03:48 PM   #4
TXCSSU
Drives: 2022 ZL1 M6/Nissan Leaf
I'd use whatever tires I do the most driving on, and that's even if I have track tires.
TXCSSU is offline   Reply With Quote
Old 04-11-2022, 03:53 PM   #5
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
Either of those tires should produce equivalent #s, go with the ones you plan on driving on. DR will reduce #s on dyno, nothing you are using would do that.
Old 04-11-2022, 04:44 PM   #6
clg82
Yes the dyno shop will be saving the CARB tune and I can switch back to it when it comes time to smog in 6 years
Old 04-11-2022, 04:45 PM   #7
clg82
Thanks everyone for the responses, I'll probably go with the stock tires than since that's what i'll be using mostly in the summer time.
Old 04-11-2022, 05:32 PM   #8
Mac7504
Mac7504's Avatar
Old 04-11-2022, 05:33 PM   #9
JSH
JSH's Avatar
Drives: '20 ZLE
dyno'd with my 4S street tires
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO.
15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR.
100 octane: 1045hp/1055tq.
100 octane + Alky MAF Meth (1) 10+:
Old 04-11-2022, 07:09 PM   #10
serper3
serper3's Avatar
Drives: 2018 Camaro ZL1 1LE
interested in what your car will put down!!
Were are you in CA? I am waiting until my powertrain warranty is up and the CARB finally issues the CARB EO for the kit. under a year left go go.
will be doing lots of HPDEs though (first one with the car in two weeks) so I want to find a good tuner who can tune partial throttle, etc well. curious what your experience will be with this setup!
Thanks,
serper3 is offline   Reply With Quote
Old 04-11-2022, 07:21 PM   #11
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I believe many people have run the stock tires at this power level. If nothing else, the shop could add VHT or something on the rollers to help with traction.
'20 ZL1 Black "Fury"
Old 04-11-2022, 08:43 PM   #12
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Any tires but drag radials. Drag radials will produce lower numbers.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 04-11-2022, 10:03 PM   #13
clg82
Thanks,
I’ll post up what my final numbers are and all the modifications for the California peeps that are interested. I’m going for what radz has going since his car from what I believe is a monster. The CARB tune as you may already know leaves a lot to be desired in the 2650, it’s still an unbelievable upgrade with the CARB tune, but I feel like I’m missing “something” by not having a tune that utilizes all of the horsepower that may be available. After i get it dynoed and tuned, I’m going to learn how to drive it again, and than go with a bigger snout and throttle body, and than learn how to drive it……again…..haha
Old 04-11-2022, 10:35 PM   #14
Mac7504
Mac7504's Avatar
The frustrating part is not knowing how the carb tune will be acceptable when the state of CA has an inane new smog statue that ANY tune will be an auto fail.
I've still got to speak to my smog guy on this. But then again we have years to go to worry about it.
