Old 04-09-2022, 11:36 PM   #1
1LEASYE
Drives: 2018 Camaro 1SS 1LE
Oil Level at the start of track day
Hey Everyone,
What is the generally preferred oil level before starting a track day/2-day track event?
I would assume starting an event with the Oil Level at 50% would be ok but I want to get others opinions on the matter based off oil consumption during track days with these LT1 motors
2018 Camaro 1SS 1LE
1LEASYE is offline   Reply With Quote
Old 04-10-2022, 12:54 AM   #2
2004YZFR1
Drives: 2020 Chevrolet Camaro Coupe 2SS 1LE
The oil level should be at the top of the hatch mark. Then just check the level during the event. Bring an extra quart in case you need to top it off a bit. I’ve been to 3 track days so far and my 2020 2SS 1LE didn’t use any oil.
2004YZFR1 is offline   Reply With Quote
Old 04-10-2022, 01:30 AM   #3
synolimit
Drives: 22 ZL1 1LE A10
I think it’s full too. Yes I know it’ll expand but it’s more of a gforce pickup tube issue. I think the auto trans also need filled more, have to go back and look at that too.
synolimit is offline   Reply With Quote
Old 04-10-2022, 11:33 AM   #4
5.M0NSTER
5.M0NSTER's Avatar
Start at the top mark. There is nothing to be gained by starting lower.
5.M0NSTER is offline   Reply With Quote
Old 04-10-2022, 01:14 PM   #5
Christian1LE
Drives: 2004 BMW 330CI, 2022 1SS 1LE
My car burned oil my first track event at 1700 miles. It hasn't burned anything since (5 trackdays)
Christian1LE is offline   Reply With Quote
Old 04-10-2022, 02:01 PM   #6
nprario
nprario's Avatar
Drives: 2017 1ss 1le HBM
I always change my oil before track days and put in exactly 10 quarts with a filter. Gets me to around half to slightly higher on the hash marks. I think if you fill to the top of the hash marks you may be slightly overfilled.
nprario is offline   Reply With Quote
Old 04-10-2022, 09:05 PM   #7
synolimit
to the top wouldnt be overfilled, itd be filled. and that little extra may help per GM if youre pulling to many G's in a corner so you dont suck up air in the oil pick up.
Old 04-11-2022, 09:47 AM   #8
1LEASYE
Good info to pick up on.
I'm running Watkins Glen and Road Atlanta back-to-back so the motor will get a hefty working plus I'll be driving to and from both tracks.
2018 Camaro 1SS 1LE
Old 04-11-2022, 05:43 PM   #9
synolimit
just keep it toped off when cold. im sure we get blow by and some will be burned up.
Old 04-18-2022, 08:39 PM   #10
cdrptrks
cdrptrks's Avatar
Agreed but in my experience I need to leave the car sitting for serval hours to get an accurate dipstick reading. Mine burns less than a quart per 10 track days so I don't bother to check the level during an event, just before and after each day on track.
Old 04-21-2022, 03:19 PM   #11
dsheffer46
dsheffer46's Avatar
Drives: 2018 Camaro 2SS 1LE
Doesn't the performance manual call for an extra quart (total 11) to be added before track use?
dsheffer46 is offline   Reply With Quote
Old 04-21-2022, 07:48 PM   #12
Dabjbr
Dabjbr's Avatar
Drives: 2020 SS 1LE
No it does not. Read the manual carefully. It calls for the extra oil on the 4/6 cylinder motors but NOT the v8 SS.
Don’t fret, I misread it too initially.
Dabjbr is offline   Reply With Quote
Old 04-21-2022, 08:46 PM   #13
dsheffer46
dsheffer46's Avatar
Dang, you’re right! Thanks man. I need to get that secret decoder ring from GM. Their guidelines are all over the place…
Old 04-24-2022, 12:00 AM   #14
synolimit
dont they say it for the tranny or is that only on the c8?
