Old 04-07-2022, 12:27 PM   #1
Conner0388
Drives: 2016 Chevy Camaro 2SS
E85 tuning questions
So I’m trying to find the difference between getting a flex fuel kit or just getting a tune for 93 then a tune for e85. I think with the flex fuel kit will allow me to use a mix between 93 and e85. What are the negative of just getting a tune for 93 and a separate one for e85 without the flex fuel kit.
Conner0388 is offline   Reply With Quote
Old 04-07-2022, 12:29 PM   #2
Conner0388
Or do they do just a flex tune without the kit?
Old 04-07-2022, 12:31 PM   #3
The big huge negative is that you have to keep the ethanol level constant, because without the flex fuel kit the car won't be able to measure E content and adjust stoich, thus you have to "bake in" a fixed E percentage into the tune and get exactly that (or only 93) every time you fill up. If you don't deplete the tank completely each time, you will inadvertently blend your fuels.
Massive PITA and risk just to save $450 or so, I don't think it's worth it.
Old 04-07-2022, 01:50 PM   #4
FlukeSS
FlukeSS's Avatar
Drives: 2020 Camaro 2SS A10
This gai gets it ^
Flex fuel myself. Not ready to dedicate the car to a fixed tune point regarding fuel mixtures. Its different if it was a dedicated track/drag car. Then I would consider it.
Old 04-07-2022, 02:06 PM   #5
BruceWayne1LE
BruceWayne1LE's Avatar
Drives: 2018 Camaro SS 1LE M6
I can’t even think of any benefits of tuning your car to 1 fuel. It’s a no brainer to get flex fuel.
Camaro 2SS 1LE, MBRP Catback, Mishimoto Catch Can, Rotofab dry, TSP1 7/8” headers,DSX FF, Pray ported MSD, 95mm TB
492WHP 473WTQ
BruceWayne1LE is offline   Reply With Quote
Old 04-07-2022, 04:33 PM   #6
WillyZ83
WillyZ83's Avatar
Drives: 18 zl1 garnet red
I did the flex fuel kit and glad I did. Spend the money and get it tuned properly.
WillyZ83 is offline   Reply With Quote
Old 04-07-2022, 05:00 PM   #7
TP2SS
TP2SS's Avatar
Drives: 2016 2SS Convertible
I've given up on getting a flex fuel system. $350 or so for the kit (not bad) but you can't find anyone to give you the tune without doing a $700+ dyno session. Totally unnecessary if you have NO OTHER mods. GM sells thousands of cars with flex fuel ECUs with no dyno-ing of each one. But apparently there's no "standard" flex fuel tune that can be loaded remotely. I've contacted a few tuners asking why they can't, don't, or won't have a standard flex tune for no-mod cars and they all say yada, yada, yada about they need the car there for whatever. When I point out to them the reasoning I list above...crickets.
Not going to spend $1000+ just to get flex fuel capability on a car I'm never going to mod beyond that to save a few bucks on a fillup or get a few more HP from!
Hyper Blue/Ash Gray
A8
Magnetic Ride Control
Dual Mode Exhaust
2019+ version Split Spoke Silver Wheels
Navigation
Silver Rally Stripes
TP2SS is offline   Reply With Quote
