04-06-2022, 04:43 PM | #1 |
Drives: 2010 SS L99 Join Date: Sep 2018
Made +41 rwhp from heads and NW 102mm TB
GPI has done it again! Got my numbers from Ben at GPI today, and picked up 41.3 rwhp at 7600 rpm, and 14 ft lbs of torque. These were my stock heads with GPIs porting and swapping to LS3 hollow stem intake valves, stock TB to the Nick Williams 102mm that matches the LOD intake snout, PAC .700 springs, and FIC 850cc injectors. I am ecstatic over the numbers so far and can't wait to pick it up and see how it feels!
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 Last edited by Chris49066SS; 04-07-2022 at 10:04 AM. |
04-06-2022, 04:57 PM | #2 |
Tri-County Camaro SWFL
Man basically 525 from an auto. Thats impressive.
04-06-2022, 06:47 PM | #3 |
Nice gains!
2014 Camaro SS L99, Ashen Grey w/Black Leather - Build thread - http://www.camaro5.com/forums/showthread.php?t=491561
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
04-07-2022, 07:34 AM | #4 |
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust Join Date: Sep 2014
Nice gains, thanks for sharing. Thats a ton of rpm!
Looks like you didnt gain any torque, just shifted peak (from 4900rpm to 5500rpm).
2010 Camaro SS M6 - 416ci TT 989rwhp/1031rwtq @ 20psi
2014 ZL1 A6 Vert - Headers and CAI |
04-07-2022, 08:10 AM | #5 |
Drives: 2012 Camaro SS Join Date: Dec 2019
Damn those are amazing numbers for a auto.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
04-07-2022, 08:45 AM | #6 | |
a higher stall , if that could have been a thing
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 |
04-07-2022, 11:18 AM | #7 |
Wow Chris, holy crap!! That's impressive my friend!! Glad to see you finally get it all squared away and exceeded your expectations! Nicely done sir. She's gonna be really fun to drive and run at the track. Hitting those high rpm's safely is going to be pure music!! Mine sings a real nice tune above 7200... Not sure what stall you have, but the 4200-4500 I did really made up for the lost tq I experienced with the 3200 and the LOD.. Enjoy that monster!!! Yes sir..
04-07-2022, 05:09 PM | #8 |
Thanks guys! I'm literally about drooling for those timeslips I have to say, it makes me hungry for solid roller territory, but its almost primed for boost. TH400 and drivetrain first, or Procharger next? I can't decide!!!
04-07-2022, 09:01 PM | #9 |
Damn Chris, that is awesome!
I knew it! I keep hearing from people online 'Oh, the LS3 heads already flow so good that there is little to no benefit from porting or aftermarket heads...waste of money, blah blah bla.' With the mods you have already done, 41 rwhp is a massive bargain vs. what you likely paid for that port work -those are aftermarket head gains right there. I know that's not 41hp just from the heads, but jeez...525 NA wheel HP on an L99 bolted to a 6L80? Freaking awesome, and an inspiration to those of us reaching for the 500 club. Oh man, I need some more $$$ and a trip to Arkansas! I do need to ask though, are those TQ numbers low for you build? I would have expected a bit higher or am I wrong here?
04-08-2022, 09:51 AM | #10 | |
And, InFiD3ViL, I feel as soon as I went to the short runner LOD intake, yes, it murdered the torque, as Ryan said. My 60' didn't change from before and after that mod though, it stayed in the 1.5x territory, and picked up ~.1 in the 1/4, but I feel it was the heads and TB that really opened it up and let it do its work (dyno-wise) and is still proof that its designed more for a higher rpm solid roller or boost application, as I am starting to push an NA hydraulic roller setup closer, (not to), but closer to the max. I've got my eye on a track around here, and hopefully it won't be long before I can get some timeslips!
04-08-2022, 10:21 AM | #11 | |
So all those people online stating there isnt much to gain are right on... if they mean for normal LS operating conditions. Most people dont have setups that rev north of 7krpm.
04-08-2022, 03:02 PM | #12 | |
04-08-2022, 08:55 PM | #13 | |
04-10-2022, 05:43 AM | #14 | |
Drives: 13 1LE 1SS/05 ZX10/02 Silverado/14 Join Date: Nov 2014
02 Stepside Silverado
05 ZX-10 13 1LE 14 Nightrod Special |
