Old 04-02-2022, 09:52 AM   #1
1LE_Blue
Drives: Chevy Camaro ZL1 1LE
Drag Tire for Rear - Question *Revised
Hey All,
Appreciate the feedback. Went with the 17x10’s (rear) Weld Racing - Belmont.
Was about to order the MT Street R but I’m hearing I should go with the MT Street R bias ply….because I have a manual, around 640whp. Do you agree? I planned on keeping the original wheels/tires up front. Will this cause the vehicle to feel more unstable down the track? Hope I’m making sense…
Original Ask——————————————————————————————————————
I’m looking for a set of rims / tires for when I go to the strip this summer. Nothing crazy expensive. I’m around 650 rwhp. At this point, I plan on going with the MT Street R’s…but I need help on the size….I know I must select the rims first.
Looking for a 17’’ rim that will not require any modifications to the 1LE. I see a lot of 17x10’s…which is narrower than the stock rim….is this an issue? Seems like that could look odd.
Tire size?
Current diameter in the front 26.7” - Michelin pilot sport 4s. Not changing the fronts. Just looking to do this a few times a year. Thanks in advance.
https://www.speedwaymotors.com/Weld-...65,467277.html
Would this rim require any modifications to the rear of the ZL1 1LE?
Also, would I be looking at a 305/45/17 tire for this rim?
1LE_Blue is offline   Reply With Quote
Old 04-02-2022, 10:05 AM   #2
s346k
s346k's Avatar
Drives: like an old lady
passing along an observation from a car with 200 less whp.
the mt et street r tires (275/40/17) did not play well with the stock front wheels/tires on my car. squirmed like a bias ply/radial combo. i imagine your car would only do it more with stiffer suspension and more power.
Old 04-02-2022, 10:58 AM   #3
Duramacr1
2Spdsy
Duramacr1's Avatar
Drives: 2021 Camaro LT1 A10
At 650whp and a heavier ZL1 , your at the point where you might want to get a beadlock wheel since your probably gonna keeping raising the power .
Duramacr1 is offline   Reply With Quote
Old 04-02-2022, 11:02 AM   #4
laynlo15
Drives: 2022 Lt1 A10
I would not run a 26.7 inch tire on a boosted application like the diameter you have on the front. Stay around 28 inches and look at the 305 45 17 Street R on a 10.5 Race Star Wheel. I ran those and I was about 870 and went 9.41@147 with 1.35 60ft times. Some run that 26 inch tire on NA cars but I don't think you'll ever hook with a 26 inch since the A10. I made 100s of pass on the 28 tall tire and thats the way to go.
Old 04-02-2022, 12:53 PM   #5
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Ideally he needs a 27.5 in the front and a 28 in the rear. since he is not willing to change the front then he might as well just put a 305/30/20 555r2(27") on the rear and call it good enough. That tire has been 9.9's on a C7ZR1 with good track prep.
Old 04-02-2022, 03:17 PM   #6
s346k
s346k's Avatar
i would definitely not use a 26" rear tire on this car. minimum 27. i was simply bringing attention to the tire itself he was wanting to use. i can only assume his car will push worse than mine under acceleration of he tries to use a (really) soft sidewall rear tire with that gy sc3r front.
Old 04-03-2022, 10:02 AM   #7
1LE_Blue
Appreciate the insights.
Old 04-03-2022, 10:03 AM   #8
1LE_Blue
Thanks.
Old 04-03-2022, 10:04 AM   #9
1LE_Blue
Good info. Thanks
Old 04-03-2022, 10:05 AM   #10
1LE_Blue
Thanks for the info.
Old 04-04-2022, 09:26 AM   #11
Jhunsberger
Jhunsberger's Avatar
Drives: 2017 Camaro 1SS M6 (SOLD)
M6 SS Whipple here making around the same RWHP. Here is my setup, however I do have skinnies up front too. Been 10.70's at 132 on this setup.
Front
Wheels: Race Star 92's 17x4.50 5x120BC 1.75"BS GLOSS BLACK
Tires: M/T ET FRONT 27.5/4.0-17
Rear
Wheels: Race Star 92's 17x10.5 5x120BC 7" BS GLOSS BLACK
Tires: M/T ET STREET R BIAS 28x11.5-17
Tires have worked well. I dont really care for the Race Star wheels. Wish I would have just spent the money for better quality wheels, they are heavy for what they are and the lug nuts suck. Get yourself some extra lug nuts if you do go with the Race Stars. They work and they are probably your least expensive option.
Stock: 416hp/427tq, 12.21 @ 116.80
Modified 02/2019: Whipple SC w/ 3.500 pulley, LT4 fueling, NW 103 TB, Roto-Fab Big Gulp, Kooks 2" jet coated, full Borla ATAK exhaust, DSS axles, Gforce driveshaft.
Tuned by EFX Tuning 688hp/632tq
Best 1/4 to date: 10.705 @ 131.92
Jhunsberger is offline   Reply With Quote
Old 04-04-2022, 12:19 PM   #12
JSH
JSH's Avatar
Drives: '20 ZLE
Originally Posted by 1LE_Blue View Post
Hey All,
Mickey Thompson ET Street R 305/45/17 (drag radials) on, say, a Weld or Forgestar lightweight (<20#) bead lock wheels
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO.
15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR.
100 octane: 1045hp/1055tq.
100 octane + Alky MAF Meth (1) 10+:
Old 04-06-2022, 07:14 PM   #13
TOSTO RACING
STOCK ELIMINATOR
TOSTO RACING's Avatar
Drives: STOCKER
Always run the most sidewall you can. It will help it hook.
5664 GHI/SA
CAMARO
TOSTO RACING is offline   Reply With Quote
Old 04-06-2022, 10:10 PM   #14
JSH
JSH's Avatar
Drives: '20 ZLE
What tire pressure do you run? I previously suggested 18 psi, but for a 3800-4000# car, closer to 20 might work best. Need someone to video my tire to see what it does on the hit.
2020 ZL1LE A10.
