Old 03-28-2022, 11:56 AM   #1
Cjw
Drives: 370z, Srt-6
Zl1 1le front driver clicking noise
2018 Zle 18500 miles, having an loud click noise that can be heard in the cabin. Low speed bumps, slow turns, non rotational. tried tightening the sway bar endlinks, plenty tight already. I have read a few people having the shocks replaced under warranty, called Chevy but they can’t get it in until May 5th. Anybody have any recommendations? If its something I can tighten for the time being I would like to autocross over the next two weekends, or at the least be able to drive the car without worry.
Cjw is offline   Reply With Quote
Old 03-28-2022, 12:12 PM   #2
closs2sx
closs2sx's Avatar
Drives: 1970 chevelle
take wheel off clean hub and wheel mounting surfaces (use a flat stone where possible) and put wheel back on and re-torque to spec. If that doesn't fix it take it to any shop that does safety inspections and have them check the ball joint and strut. If you were close to nh I would do it for you.
On Order 2018 ZL1 1LE Garnet Red Tint Coat Metallic
MY Car
2015 Z06 Z07
Daytona Sunrise Orange Metallic
Dads Car
2013 ZL1 vin 963
Crystal Red Tint Coat/Black Wheels
Exposed Carbon Fiber Insert
6 Spd Manual
closs2sx is offline   Reply With Quote
Old 03-28-2022, 04:01 PM   #3
Cjw
Drives: 370z, Srt-6
I will give this a shot later this week, I was able to rock the car on the fender slightly and sounded like it was at the top of the strut, I tighten the top bolts down with no luck, guessing its a bad strut
Old 03-28-2022, 04:33 PM   #4
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Check the struts - i had both fronts come "loose" - replaced under warranty.
Grip tire firmly and push in/out.
The other cause is front sway links - there is another post about that in detail.
ing for grip.
http://www.motorsportsne.com/
Old 03-28-2022, 04:53 PM   #5
Mac7504
Mac7504's Avatar
Drives: 2003 Monte Carlo SS SLP, 2022 ZL1
Tie rod?
Mac7504 is offline   Reply With Quote
Old 03-28-2022, 05:38 PM   #6
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Originally Posted by Mac7504 View Post
Tie rod?
I had one fail too, inner tie rod to be specific.
ing for grip.
Old 03-28-2022, 05:39 PM   #7
Mac7504
Mac7504's Avatar
Anytime I've had a clicking on my car, it was the tie rod.
Old 03-28-2022, 06:53 PM   #8
Chippy
BanHamWatch
Chippy's Avatar
Drives: 21 ZL1 1LE
I get the boing sound once in awhile when it’s very hot outside. Can’t ever replicate for dealer to warranty any suggestions would be appreciated sorry to hijack
2021 ZL1 1LE
Auto
Chippy is offline   Reply With Quote
Old 03-28-2022, 07:09 PM   #9
SATINSTEEL1LE
Drives: 21 ZL1
It’s the lugs and the rotor hat surfaces. As said remove the wheels and clean the rotor surface where it faces the wheel. Then put back on and retorque the lugs.
SATINSTEEL1LE is offline   Reply With Quote
Old 03-28-2022, 08:22 PM   #10
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
I get clicky clacky noise going into reverse and loading unloading driveline up the driveway. Yup "can't find source of noise"
ing for grip.
Old 03-28-2022, 09:50 PM   #11
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
make sure when you are tightening the sway bar end links to have a 6mm allen on the stud as you could feel the 18mm nut is tight and it isn't. If you did it this way then fine. 1/16 of a turn loose will cause a clunk.
Old 03-29-2022, 08:46 AM   #12
Cjw
Drives: 370z, Srt-6
Thanks for the updates everyone, I will jack the car up Friday and check all of these just to be safe, keeping the appointment at chevy just in case, praying its not the strut
Old 03-29-2022, 09:01 AM   #13
SJFGTO
Oh Oh it's Friday Night!
SJFGTO's Avatar
Drives: 2018 ZL1 1LE Nightfall Gray
I had a clicking noise from the right front. I was sure it was an end link. Took it to the dealer and it turned out to be a bad supercharger belt. I did not believe it, but the dealership replaced the belt and the noise disappeared.
Four that wanna own me
Two that wanna stone me
One says she's a friend of mine...
SJFGTO is offline   Reply With Quote
Old 03-29-2022, 09:50 AM   #14
Crushed 1LE
Crushed 1LE's Avatar
Drives: 2022 ZL1 1LE
Had exact same issue. Bad DSSV. Replaced. Fixed.
Crushed 1LE is offline   Reply With Quote
