Old 03-25-2022, 07:48 PM   #1
427
Drives: Camaro
Intake manifold
Does anybody make an intake manifold for adding port injection on the LTG?
Kurt
427 is offline   Reply With Quote
Old 03-25-2022, 09:35 PM   #2
95TA - The Beast
Drives: 2014 Cadillac CTS4 2.0T Performance
I have looked quite a bit as of late and one guy did his own. It was done in a weaker section of the intake and in a way that it changes wiring routing and a bunch of other stuff.
But, there are no kits or pre-built units.
I have actually came up with a way to make it work, but to accomplish it in a "bulletproof" manner it is quite expensive and very involved to get "right".
I may do it as an exercise and a way to see if I can actually get max power out of a non-e85 setup on 93 octane, but I really shouldn't even need it with the proper parts (cam, turbo, intercooler, piping, etc). Problem is to pull it off looks to be around $1k in parts going progressive, direct-port, good controller, etc. I do have an extra intake manifold on hand to do the build.
If I do get a system done I might end up offering doing the build for a cost. As I stated it is quite involved compared to most setups.
95TA - The Beast is offline   Reply With Quote
Old 04-05-2022, 09:42 AM   #3
cooper1965
Coopers Camaro
cooper1965's Avatar
Drives: 18 Flex Fuel LTG
G1 Pro. Warning, tuning for this is not for a novice or even some veterans.
Flex Fuel tuned by me using HPT-:-
---My Build Thread---
-----My IG PAGe-----
Old 04-06-2022, 01:42 PM   #4
Start The Machine
Start The Machine's Avatar
Drives: 2016 M6 2.0T
Tuning nightmare.
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, RPI Designs SS 1LE Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
Start The Machine is offline   Reply With Quote
Old 04-06-2022, 01:52 PM   #5
Start The Machine
https://prometh.com/collections/4-cylinder
Old 04-09-2022, 07:26 PM   #6
cooper1965
Coopers Camaro
cooper1965's Avatar
Originally Posted by Start The Machine View Post
Eigh... I'd be marginally worried about tapping into a plastic composite intake for bungs... Granted, I do have guys that have done this, but I also ask they keep a mini fire extinguisher on hand....
Old 04-10-2022, 09:33 PM   #7
427
Drives: Camaro
That takes a 90mm LS throttle body?
Kurt
Old 04-11-2022, 10:20 AM   #8
Start The Machine
I agree, creating your own threads in the plastic intake is sketchy at best. For the guys that you know that have done this, how did it perform? Did all of the cylinders have equal spray volume?
Old 04-13-2022, 08:41 AM   #9
cooper1965
Coopers Camaro
cooper1965's Avatar
One guy has been running around for almost 2 years now like this. No issues. Recently took a peak inside the engine, every cylinder seemed to be equally clean. So I would say yes. Individual cylinder monitoring would be great to have... ..
