Old 03-25-2022, 03:50 PM   #1
SShelly
Drives: 17 Camaro SS
Post Getting Knock at Higher RPM.. Need Assistance
I am having issues with having knock at the very high rpm starting at 5600.. i have already searched through many of the tuning forums for answers but haven't found a solution. Also this is my first post so if you have any suggestions for what i may need to include for more assistance please let me know! Also this is my first experience tuning an actual vehicle so any improvements that can be made that you see would be great
17 camaro ss
MSD Intake
2" headers
NGK iridium spark plugs
SShelly is offline   Reply With Quote
Old 03-25-2022, 06:02 PM   #2
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
I’m on my iPad so I can’t read your tune, but have you desensitized the knock sensors to compensate for your long tube headers? Has the fueling been adjusted after your mods were done?
Old 03-25-2022, 10:18 PM   #3
95 imp
Dumb Ass Deluxe
What octane are you running?
Old 03-26-2022, 04:52 AM   #4
wnta1ss
Drives: 2017 Camaro 1SS
First thing related to your 5600+ problem that I would suggest is to zero out table ECM 12785, Engine>Spark>Retard>Static Retard> vs Cylinder (that is a button). Those static retard values starting at 5600 rpm (which your tune still has) can show false knock in the log, which is obviously confusing when you're trying to figure out if any real knock is happening.
Old 03-27-2022, 04:05 PM   #5
SShelly
I have been tuning this car on 93 octane
17 camaro ss
MSD Intake
2" headers
Old 03-27-2022, 04:07 PM   #6
SShelly
I haven't done this.. how would i properly go about doing this.. Also i have done LTFT tuning for fueling and updated the MAF based on that
17 camaro ss
MSD Intake
2" headers
Old 03-27-2022, 04:09 PM   #7
SShelly
Thank you Definitely will try this our and let you know what happens
17 camaro ss
MSD Intake
2" headers
Old 03-27-2022, 07:37 PM   #8
wnta1ss
Hope it helps. Will also suggest adding some more channels to VCM Scanner while you're working on your spark:
Base Advance
Flex Fuel Advance
Coolant Advance
IAT Advance
Burst Knock Retard
Knock Learn Factor
Old 03-28-2022, 09:54 AM   #9
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I looked at your tune...all of your spark retard stuff is stock. Zero out static retard as mentioned above and also need to desensitize the knock sensor threshold for each cylinder.
Old 03-28-2022, 10:26 AM   #10
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Maybe start somewhat small with the de-sensitivity, too. Maybe try 5%, then 10% if 5% wasn't enough, etc.
'20 ZL1 Black "Fury"
Old 03-28-2022, 06:12 PM   #11
SShelly
So i ended up changing the static retard to 0 like mentioned and just to see if anything would change.. i upped the peak torque also since it was getting to close to the Maximum Torque Value.. it decreased the knock but there is still a little there
17 camaro ss
MSD Intake
2" headers
Old 03-28-2022, 06:14 PM   #12
SShelly
Okay! should i lower the spark advance before i do this or leave it the same?
17 camaro ss
MSD Intake
2" headers
Old 03-28-2022, 09:11 PM   #13
KingLT1
KingLT1's Avatar
Lower the spark before doing anything. If the knock is still there then it's false. Next step is to reduce knock sensitivity until it goes away.
Old 03-30-2022, 01:10 PM   #14
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I've also mixed several gallons of 100 octane to very low pump gas to try to eliminate false knock, too, but flashing lower spark might be a better option. I used that method to avoid flashing, but if you're already in there, it'll be cheaper to flash.
2017 camaro ss, engine knock, tuning advice
