Black lightning
Zle track alignment
Waiting on my car to be finished! From a vette tech at GM. question can the track alignment be done without setting the front camber to the track setting? Jus curious I hope he did it I want the front end lower. I was trying to explain it him not sure he got it. Welp will no soon
[ 2021 Camaro ZLE 10 speed
Drives: Faster than yours Join Date: Nov 2021
You can just look at the top of the struts to see if he adjusted the camber plates or not. But why would you trust the guy to do a track alignment if he can't even understand how to adjust the camber plate? I'd be more worried he has the left side of your car at the extreme low end of acceptable range and the right side at the extreme high end of the acceptable range since he seems to just know the bare minimum.
#3 | |
Black lightning
That picture isn't the ZLE track alignment... should be -2.7 camber up front for ZLE track.
![]() Drives: Garnet Red / ZL1 1LE Join Date: Apr 2016
That is not a track alignment.
First order is to turn the front struts 180' where it will show the track camber sign. Then the alignment can be corrected. Front camber needs to be -2.75 on both sides. Front Toe can be anything from 0 to 0.05 in.
#SAVETHEMANUALS
Black lightning
I'm taking it somewhere else that knows the Zle like the back of his hand because the dealer had no idea wtf they were doing
#7 |
![]() Drives: 2020 ZLE A10, 2018 F250 Diesel Join Date: Apr 2020
If you don’t track the car, definitely don’t go -2+ on camber. You’ll just eat up the insides of your tires. I think the -1.5 he gave you is fine for street use. Just keep an eye on your tire wear.
#8 |
I'm testing this right now. I've got a set of PS4S that came on the car with about 50% life left. I took down the tread depths before I did the exact manual track alignment and then I'm gonna check once the inside cords and see how badly it's worn on the inside vs the outside. Currently I have almost perfectly even wear throughout the tire.
#9 |
![]() Drives: 22 ZL1 1LE A10 Join Date: Feb 2022
no you wont!! zero toe with -2.8 will last just fine! toe eats tires, not camber
#10 |
That's what I've always been told which is why I'm running my current experiment. I wish I still had the alignment printout from my track toy C7. That car had around a -2.1 camber, but I don't remember the toe off the top of my head. That car for sure ate up the inside of the tires though.
#11 | |
Black lightning
Ok thanks BUT, I made an appointment for next Friday with 89x motorsports with the guru of zl1 1les who is at most of track events around with his cars. He's giving me a dual track alignment track/drag and installing the SPL lockout kit. Not sure how he's gonna set it up but I'm DEFINITELY CONFIDENT
#12 | |
#13 | |
#14 |
We're talking about these: https://www.splparts.com/products/ca...c-lockout.html
