Old 03-25-2022, 08:56 AM   #1
Timbo-1LE
Timbo-1LE's Avatar
Drives: 2017 SS 1LE
3R heat cycle tips?
Hi,
SS 1LE, after five sets of standard Goodyear 3's, I grabbed a set of 3R's from tirerack, but to heat cycle them was a 60 day wait.
In the past, I simply put 200 miles on them prior to track use.
I know these will wear quicker being 100 Tw.
Question, do I need to do anything different than described above prior to track use?
Thanks
Tim
Timbo-1LE is offline   Reply With Quote
Old 03-26-2022, 06:01 AM   #2
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
Ideally you would heat cycle them 1 time and wait at least 24 hours before running them again. That can be pretty hard to do on track so I've done it by driving them on my local "test road". But I've also had to go straight to track with a brand new set and it didn't seem to matter much for longevity. What will kill them is driving on them to the track depending on distance. They need a lot of camber, I'm at -3 front and -2 rear and its not enough so I will be getting more soon. Also tried flipping them on the rim which works but not as fast as normal.
Mods: MSD, Headers, 95mm TB, high flow cats, full 3" exhaust, SPL, MCS 2-way remotes, sway bars, rear diff lock outs, Sparco racing seats, 6 point harness, CMS roll bar, Nine lives wing, 6" splitter, ACS canards.
www.youtube.com/@Racer_Mike87
Old 03-26-2022, 06:26 AM   #3
Timbo-1LE
Timbo-1LE's Avatar
Drives: 2017 SS 1LE
Thanks for the tip.. I trailer so that should help... Interested in seeing the difference.
Old 03-26-2022, 09:40 AM   #4
khcoaching
khcoaching's Avatar
Drives: 2021 1SS 1LE
I have a 20 min drive to the track with mine and if they are not getting up to track temp, how is this an issue? Or is it a long drive with a lot of camber issue?
Ken
khcoaching is offline   Reply With Quote
Old 03-27-2022, 06:30 AM   #5
Timbo-1LE
Timbo-1LE's Avatar
Drives: 2017 SS 1LE
Not sure. But as stated, I trailer mine. With the base 3's I would just put a couple of hundred street miles on them and that seemed to do best for track wear. Looking forward to seeing the difference!
