03-22-2022, 08:16 AM | #1 |
Drives: 2017 CAMARO ZL1 Join Date: Dec 2017
HELP! ———- MAF FUSION CONTROLLER - PORT INJECTION
WHO SELLS THE MAF FUSION CONTROLLER?
LOOKING TO DO PORT INJECTION ON A 2018 CAMARO ZL1 MAGNUSON 2650 TOO HIGH PSI PORT INJECTION PLATES NEED THE CONTROLLER. |
03-22-2022, 10:37 AM | #2 |
Petro-sexual
CAN'T YOU ORDER ONE FROM TOOHIGHPSI?!!!...
Good Lord...
03-22-2022, 11:37 AM | #3 |
03-22-2022, 01:55 PM | #4 |
Petro-sexual
Have you tried ADM Performance? I'm seeing they might be a distributor.
03-22-2022, 06:00 PM | #5 |
Guess you’ll have to hope to find one in stock from a distributor. I see MAF fusion site also is showing no stock.
03-24-2022, 12:37 AM | #6 |
03-25-2022, 08:48 PM | #7 |
Any help? Anyone have one for sale?
03-25-2022, 09:13 PM | #8 |
I see Mike @ TooHighPsi is now selling the Microsquirt instead. I would imagine that would be capable of doing the same thing or else he likely would not sell it. Or you go high end and get a Holley Dominator… good bit more money but capable of WAY more than the MAF Fusion…plus dual widebands for self tuning at WOT. Tough to beat that IMO.
03-25-2022, 09:51 PM | #9 |
Old badass
Drives: 14GMC 2.9 16GMC Turbos 2020Silv.6.2 Join Date: Mar 2020
The Dominator is a chunk for sure but it was plug n play with Crawford's setup so I just did it. The MF, Mike said requires some wiring handiwork but for someone that lives and breathes this stuff np. I don't. I'm too old and have an AC business to run. His plates are awesome though congrats!
I've had 7 Camaro's. All gone...for now.
Current build in progress 2016 GMC4x4 RCSB twin hair dryers ~1k whp fbe port inj 1/8 mi & stealth street terror |
03-26-2022, 12:44 AM | #10 | |
Drives: 2018 Cadillac CTS-V Join Date: Jul 2012
I noticed it has a wideband afr target table. Maybe it’s easier to dial in as that’s one of the good points of the Holley. Still wish there was some plug and play harnesses from him but, the install turned out clean on my car despite it. |
04-02-2022, 04:06 PM | #11 |
Did you ever find this or have you decided on another option? I don’t see the MAF Fusion listed at Too High PSI site today. Maybe this was a result of supply chain issues. However, the Microsquirt is also showing no stock.
04-03-2022, 06:34 AM | #12 | ||
Dyno Show Queen LOL
Haltech elite 950 or higher and WBII pretty affordable..
04-04-2022, 12:42 AM | #13 |
Really depends on what will effectively control a secondary fuel injection system and what your tuner is capable of tuning. If you do it right you’re going to offload the direct injection by relying on it for low speed drive modes and start blending the port injection mid throttle.
Once he got the hang of it, my tuner felt the MAF fusion device felt about the same as dialing in a meth/alky system. He said the Holley is far simpler to dial in. The microsquirt looks interesting but, I would just reach out to Toohighpsi and ask what the deal is. He’s more than likely going to have to give heads up to a tuner on dialing in the unit. The Holley if I’m not mistaken you can just set a desired AFR and it will help you dial in the fuel curve. However until Crawford starts to make plug and play kits again - you’ll have to figure out what wires to tap into. Not different than the MAF fusion or any other kit as they aren’t plug and play exactly. |
04-14-2022, 08:23 PM | #14 |
