![]() Drives: 2018 ZL1 m6 Join Date: Mar 2022
ZL1 (non 1LE) Lowering Spring Question
I ordered H&R 1.25" drop lowering springs for my ZL1
It says it is for the ss/1le... I swore at the time I ordered it said it fit the ZL1 but now I can't find them on the website anymore Has anyone run these? https://www.phastekperformance.com/H...ings-50770.htm Part number 50770 with H&R I thought all 1le has magnetic ride, which in turn, also fit ZL1 magnetic ride When I look at these springs compared to the RST PX1s for the ZL1, the rears look insanely different Any help would be appreciated haha
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
I can't comment on those particular springs but those of us that do lower our ZL1s go with the Eibach pros.....they don't affect the magnaride at all and are a direct swap....if I were you i'd just return the wrong ones and go with something different. Just my 02 cents
What do you think about the PX1's?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '21 ZLE A10 Join Date: May 2012
Eibach worked great in my '17
![]() Drives: 2021 Chevrolet Camaro ZL1 Join Date: Apr 2021
I believe the 1LE does NOT have magnetic ride control.
The ZL1 does. The eibach springs i installed were a direct swap and compatible with the MRC.
2021 Camaro ZL1
ADM S/C Expansion Tank Dual Aeroforce gauges Eibach Pro Lowering Kit Oracle Side markers (Paint matched) Rear window "wind screen" Xpel Paint Protection Ceramic Pro Coating |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
I used the Eibach Pro Kit, its the perfect stance and doesn't interfere with the Magneride.
#8 |
![]() Drives: 2022 ZL1(FEA suspension) Rapid Blue Join Date: Apr 2019
I would go with YYZ springs from Powell Racing. There is a ton of interesting data on the web regarding their development. Not your average spring!
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: E92 BMW M3 Join Date: Oct 2012
When looking in to these, I only see 1 spring part number. Is that correct, is the same spring being used across the entire Camaro line are are there specific ZL1 springs like the Eibach?
J-Rod Built and Matt@FSP Tuned |
#10 |
Whole lotta marketing nonsense on those springs. They claim to be progressive, so are Eibachs. I get it though, small business got to do something to compete with the big business so they create a unique marketing angle that makes them sound better than their competitors with claims that can't be proven by anyone.
#11 | |
Limitless Imagination
Drives: 2018 ZL1 & 2022 Hayabusa Join Date: Dec 2016
I do know the install is the same for the SS with MRC vs ZL1.
I am not 100%, but with Eibach it seems they both SS and ZL1 use the same springs. There is just less of a drop with ZL1 due to it being lower than the SS from GM. Maybe someone can comment. I am running Eibach on my car and install was pretty straight forward. Very little ride quality difference. They claim 0.4" front and rear, but was a little lower on my car (which I definitely didn't mind). And for kicks...
2018 Camaro ZL1 - Black
- OEM Options: A10, Exposed Carbon, PVR, Nav, No Sunroof - Lightly Tinted GM Dark Tails, DD Side Markers, Morimoto 5000k, 100% LED - RotoFab Dry, Forgestar CF5V (ZLE Spec), Eibach Pro, AeroForce Interceptor, GT4 Tow Hook - Carbon Fiber (Satin): Radio, Shifter, Steering Wheel Controls, Shifter Top, AC Vents, Side Mirrors & Shark Fin 2022 Suzuki Hayabusa - Brilliant White Pearl & Shocker Yellow Wheels - +4 Arm, 240 OEM Wheel, Brock's CT (Ti) Exhaust, 1.25" drop, etc... |
#12 | ||
#13 | |
BUT totally a guess, I'd personally just call Eibach (if going with them) and inquire, if any difference it would be between Eibach's SS and ZL1 spring rates.
#14 | |
| Tags |
| lowered, lowering springs, zl1 |
