Old 03-16-2022, 06:45 AM   #1
Crazy Drywall Guy
Drives: 2018 Chevy Camaro 1ss
Texas speed drop in combo?
Anybody using Texas speed /JE piston drop in combo? Looks like the only thing readily available for drop-ins.
Crazy Drywall Guy is offline   Reply With Quote
Old 03-16-2022, 09:01 AM   #2
L78toLT1
L78toLT1's Avatar
Check with GPI. I just picked up some pistons from them. I can't speak for the availability of the rods.
I already have those so I didn't bother to check.
That being said, if the Texas Speed combo is available, and competitively priced, there's no reason not to go with them.
Baby Blue
Old 03-16-2022, 09:44 AM   #3
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
GPI is backordered.
TSP in stock.
Vengeance racing doesn't specify.
If you plan on running 93 get the 10.5:1 compression pistons.
If you are going to run E then stock compression is fine but I believe only GPI offers that. Most other drop in kits lower compression. Contact TSP to verify...not sure why it's not mentioned.
Old 03-16-2022, 10:48 AM   #4
Crazy Drywall Guy
Texas speed says -6 piston. They do offer a Carrillo piston/rod combo that drops it to 10.5. definitely running e-85. Doing JRE cam set up while it's out,just making sure I get correct piston/rod combo
Old 03-16-2022, 10:55 AM   #5
ZO6Ted
Old badass
ZO6Ted's Avatar
Drives: 14GMC 2.9 16GMC Turbos 2020Silv.6.2
+1 for King's comment. Talked to GPI on Monday they said rods are in fact backordered and no clue when they will show. I don't like the rods from TSP as they don't show to be rated high enough for me. Waiting it out.
I've had 7 Camaro's. All gone...for now.
Current build in progress 2016 GMC4x4 RCSB twin hair dryers ~1k whp fbe port inj 1/8 mi & stealth street terror
ZO6Ted is offline   Reply With Quote
Old 03-16-2022, 11:55 AM   #6
Puddin
The rods from TSP are pretty similar to the GPI versions so I wouldn't hesitate to run them. Now if you're shooting for 1000 or close to it I'd just do a custom setup and pick a stronger rod than both of those listed.
Old 03-16-2022, 12:50 PM   #7
Crazy Drywall Guy
Any recommendations for a engine builder in Michigan? Called a couple places and they want to use all their own parts before they will put their name on it,I could put it together myself but would feel better having someone assemble it for me and I will just reinstall the motor myself.
Old 03-16-2022, 03:13 PM   #8
swisstyphoon
Former GM Technician
swisstyphoon's Avatar
Drives: 2018 ZL1 A10, 06 Silverado Duramax
Did you also ask here?
https://www.strictlyperformance.parts/
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, DSX dual intank pump, Lingenfelter high flow check valve, Motion Raceworks Flex Fuel adapter, LPE Big Bore Hpfp, XDI 30% Injectors, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can.
2006 Silverado Duramax Diesel
MPI Compound Turbo
40% over Injectors
Efi Live DSP5 Tuning
Follow me on Instagram: SwissZL1
swisstyphoon is online now   Reply With Quote
Old 03-16-2022, 03:16 PM   #9
Crazy Drywall Guy
Originally Posted by swisstyphoon View Post
Actually I did,they never called me back
Old 03-16-2022, 03:25 PM   #10
swisstyphoon
Damn, I would try to reach them again..
They have a pretty cool engine build video on youtube.
https://youtu.be/EBYc0I4Qq5U
2018 Camaro ZL1 A10
MPI Compound Turbo
40% over Injectors
Old 03-16-2022, 03:54 PM   #11
Crazy Drywall Guy
I called them again,said they are super busy and will call me back tomorrow to discuss it.
Old 03-16-2022, 11:07 PM   #12
ZO6Ted
Old badass
ZO6Ted's Avatar
Yeah I was just going by what LME and Strictly list those rods as good for in their LT builds 11-1200 whp. I didn't think TSP's were that stout. If they are then hell yeah
Old 03-16-2022, 11:30 PM   #13
Puddin
Yeah they all have different opinions on them. If I remember correctly GPI were comfortable with the compstars up to 900-1000.
Old 03-17-2022, 10:34 AM   #14
ZO6Ted
Old badass
ZO6Ted's Avatar
Good info much appreciated.
