Old 03-15-2022, 11:59 PM   #1
sspddmn
sspddmn's Avatar
Drives: 2018 ZL1 1LE and 1991 Z28
NPP Question
I currently have an AWE track exhaust cat back. My county here just started upping enforcement on vehicle exhaust ordinance thanks to the uptick in sideshows. My question is has anyone Frankensteined their aftermarket non-NPP exhaust with their OEM NPP valves? Meaning has anyone measured and cut out the portion of pipes on the NPP exhaust that houses the valves and then weld them into the aftermarket exhaust? This way I can retain my AWE and use the functionality off the NPP valves. Is this even doable? Spent a lot on this exhaust and I don't want to have to spend another $2300 for a valaved Corsa or Borla. Thanks in advance.
In the garage: 2018 HBM ZL1 1LE // 2013 ZL1 (sold) // 1991 Camaro Z28 5.7L // 2022 Audi E-tron SUV (wife's car) // 2002 Camaro SS (sold)
sspddmn is offline   Reply With Quote
Old 03-16-2022, 01:16 AM   #2
sspddmn
sspddmn's Avatar
NPP Question
Old 03-16-2022, 06:56 AM   #3
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
The AWE muffler is not chambered, so the valves would not be helpful at all. You need a muffled chamber to direct the air through, like the NPP mufflers you mentioned have 2 chambers, with on being more muffled than the other.
I think your only option is selling the exhaust and replacing with an NPP muffler.
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
Old 03-16-2022, 06:59 AM   #4
mariojas
mariojas's Avatar
Drives: 2022 ZL1 M6 & 2023 Stinger GT AWD
Fun fact - Dodge has just a flap in the piddle of exhaust pipe... You could experiment I guess.
2023 Kia Stinger GT AWD - as a family car...
2022 ZL1, M6 as daddy's ass mover
Charger sold! Better to sell, than waiting to be stolen...
mariojas is offline   Reply With Quote
Old 03-16-2022, 06:59 AM   #5
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
I dont see why that couldn't be done in a muffler shop but no I've not seen any one on this forum do it.
Old 03-16-2022, 07:36 AM   #6
Drnick
Drives: 22’ ZL1
You reside in California ( San Fran area)?, if so, cops have nothing
Better to do? Enforce noise restrictions on cars?
Hmmm, very interesting.
Drnick is offline   Reply With Quote
Old 03-16-2022, 08:27 AM   #7
sspddmn
sspddmn's Avatar
Yes that's why it's called Commiefornia. Trust me, I know. 5 more years till retirement then I'm outta this shit hole
Old 03-16-2022, 09:53 AM   #8
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
The easiest solution without changing exhaust systems would probably be to order the AWE touring mufflers (which should bolt in), then add E cutouts up stream of them when you want loud.
Old 03-16-2022, 10:07 AM   #9
sspddmn
sspddmn's Avatar
I was thinking that too but as a last resort cost wise. Thanks!
Old 03-16-2022, 11:21 AM   #10
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
Magnaflow makes a mid section muffler you could install, but you lose the optionality with NPP. Its about $150 for the part, so a cheap option in the short term if you have to find a fix quick.
Old 03-16-2022, 02:25 PM   #11
sspddmn
sspddmn's Avatar
Cool thanks for the info.
Old 03-16-2022, 05:42 PM   #12
serper3
serper3's Avatar
Drives: 2018 Camaro ZL1 1LE
I don't think it is doable because its not the valves themselves that quiet the exhaust.. the muffler in your awe would have to be designed with npp in mind. there would have to be a loud straight through section in the muffler, and a quiet side in the muffler. so i do not think it would work on an exhaust that was not designed to work with npp.
i would try to find someone who has an npp exhaust and wants to trade.
serper3 is offline   Reply With Quote
Old 03-16-2022, 07:08 PM   #13
^^^ this, the exhaust needs two clearly separate paths, you can't just slap a valve into a single resonated path.
By the way, several of us here tried to tell AWE that they should offer a valved solution, to no avail (the funny thing is they already manufacture valved exhausts for other cars, just not the Camaro...)
Old 03-17-2022, 01:37 AM   #14
sspddmn
sspddmn's Avatar
Yeah I figured as much. Thanks for the info guys.
