Old 03-14-2022, 11:22 AM   #1
Paulman
Drives: Slow Corolla
Experience with 6 Piston Brakes on a V6
I'm looking to place an order for a 1LT, but trying to decide if the 4 piston upgrade or 6 piston upgrade would be better.
The car would see daily driving plus a decent diet of about 4 HPDE's a year in Advanced group. I would plan on dedicated track tires with a treadwear of 200 to 220.
Does anyone have on-track experience with either of these? I'm leaning toward the $3300 6 piston kit to be safe, but want to make sure it's worth it, especially for a V6.
Are there any aftermarket brake pad options for the factory 6 piston kit?
It would also get the factory lowering kit option.
‘21 Satin Steel 1LT 1LE
Prior:
'22 Camaro 1SS 1LE
'90 Mustang LX
'18 Volkswagen GTI
Paulman is offline   Reply With Quote
Old 03-14-2022, 12:07 PM   #2
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
do it do it on my ss it was the best $$ i every spent and the factory 6 piston kit is the same as the 1le/zl1 so tons of brake pad options
Old 03-14-2022, 04:56 PM   #3
Paulman
Thanks for the help
I forgot to ask - can the oil cooler still be ordered with the 6 piston setup?
The online configurator only allows an oil cooler with the 4 piston setup as a package
Prior:
'22 Camaro 1SS 1LE
'90 Mustang LX
'18 Volkswagen GTI
Old 04-15-2022, 09:07 AM   #4
Start The Machine
Start The Machine's Avatar
Drives: 2016 M6 2.0T
Hell, I have the 6 pistons on my 2.0T, The pedal feel and stopping power are off the charts.
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, RPI Designs SS 1LE Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
Start The Machine is offline   Reply With Quote
Old 04-15-2022, 12:17 PM   #5
SomeGeoffGuy
SomeGeoffGuy's Avatar
Drives: 2023 2SS Convertible
Lightest car plus biggest brakes - that sounds pretty awesome!
-Geoff
'16 2SS Convertible - White on white, mag-ride, NPP, nav. Sold!
'23 2SS Convertible -Same as above except orange.
SomeGeoffGuy is offline   Reply With Quote
Old 04-15-2022, 12:48 PM   #6
-Geoff
I agree, it's got to be a steering wheel knockout Pretty cool setup.
My car also has the 6-piston 1LE brakes, but it's a teeny weeny bit heavier with all the extra hardware, yet it stops extremely well with a fantastic pedal feel... now that 2.0T must be at least 400 lbs lighter.
Old 04-15-2022, 02:58 PM   #7
buckwam
Drives: 2021 camaro 1ls
Will these fit with the stock 18" wheels or do they require 20" wheels?
buckwam is offline   Reply With Quote
Old 04-18-2022, 01:54 PM   #8
BOSE ZO
BOSE ZO's Avatar
Drives: 2018 CHEVROLET Camaro LS LGX/TR3160
I’ve seen a picture of an SS with 6 pistons and factory 18’s used as winter wheels… looks like it should fit with the 18’s…. If you do a google search, it may come up…. It’s strange, the whole wheel is filled with rotor and caliper… with that said, I have 4 piston V6 1LE setup myself and they are very nice.
LorenZo
2018 CHEVROLET Camaro LS -The Giant Black SEALION-
LGX/TR3160 w/BOZE!!!!!
ig: rapidtransit
BOSE ZO is offline   Reply With Quote
Old 04-19-2022, 03:45 PM   #9
Msquared
Msquared's Avatar
Drives: Chevrolet SS 1LE
I several other SS 1LE owners are using the stock base 18x8.5 five-spoke wheels with our six-piston Brembos up front. It's close, but it fits.
Matt Miller
2020 SS 1LE
Msquared is offline   Reply With Quote
Old 04-19-2022, 03:49 PM   #10
Corbu
Drives: Camaro 2SS
I am thinking of upgrading to the SS 1LE 6 piston breaks but during the winter I run a set of cheap aftermarket 18" wheels with winter tires.
Are the 6 piston breaks guaranteed to fit on the stock 18" rim only or will an aftermarket generic 18" rim fit as well? Has anyone tried it?
Or in other words, what is the clearance required for the 6 piston breaks? I guess I can measure the inner diameter of the rims I have and see if it fits.
2017 2SS stock
Corbu is offline   Reply With Quote
Old 04-19-2022, 06:39 PM   #11
Msquared
Msquared's Avatar
Some aftermarket 18s have been tried successfully. I think you will probably be fine on clearance of the rim to the tops of the rotors, but the question will be whether or not the spokes will clear the outside edges of the calipers. I don't have a clearance number to give you on that.
Matt Miller
2020 SS 1LE
Old 04-20-2022, 06:02 AM   #12
Paulman
What's the aftermarket like for pads for the 6 piston setup?
Are there as many choices as the 4 piston setup?
Prior:
'22 Camaro 1SS 1LE
'90 Mustang LX
'18 Volkswagen GTI
Old 04-22-2022, 11:21 PM   #13
Mountain
Mountain's Avatar
For the 370mm/SS 1LE front brakes? Plenty of pad choices.
