Old 03-10-2022, 09:47 PM   #1
FKeller
FKeller's Avatar
Drives: 2018 2SS 1LE
2018 Camaro 2SS 1LE N/A Built 500WHP Miami(SOLD)
Hey all, putting a feeler out for my 2018 2SS 1LE in Summit white, Currently sitting at 199xx miles, and increasing as it is my daily.
2SS 1LE
Summit White
Sunroof
no PDR
Rear diff fluid changed at 13500+ 16900
trans fluids swapped with RP Syncromax @16900+ archoil 9100, trans temp rarely rises above 110 after the archoil. Semi common 2nd gear syncro issue not present in this car( had a identical car w/o sunroof previously that had 2nd gear issues)
0w-40 full syn. ran with archoil 9100 after build
All mods done at 16900 miles
Bolt ons
LT2 Intake, ported+ stock 87mm TB
(Have Soler performance ported 91mm effective TB still in box)
ARH headers + catted connection pipes+ xpipe. stock NPP muffler
ATI 10% underdrive pulley
E85 sensor
Internals
New Mast performance LT1 Block
Stock crank
Clevite main bearings w/upgraded thrust bearing
stock main cap bolts
stock rods
ARP rod bolts
King XP rod bearings
Diamond Pistons forged pistons (11.7 CR)
Durabond coated cam bearings
Cam Motion Titan 1 cam
comp cams 5/16 push rods
TSP valve springs/valve seals
LT1 HPFP + lash cap
Billet rear galley barbell
ARP timing cover bolts
Rotating assembly rebalanced with new pistons to within race spec+ cam bearings installed by highly respected machine shop here in Miami (Mesa Balancing)
Engine put down 470 hp/430 torque on 93 on mustang dyno at break in, with e85 + on dyno jet assumed to be 520-530 wheel.
Since taken car back for 5000 mile tune check and dyno’d again, came out to 503/461 on e70 on mustang dyno, so with straight e85+ dynojet assumed to be 530~ or thereabouts
Engine was built with intention of having a reliable daily car that just happens to put 500+ to the wheels, as such did not put ported heads, extreme thermostat, etc.
Exterior mods
C7 carbon fiberglass side skirts, wrapped in 3m satin black
ZL1 add ons deluxe rock guards
Drake muscle cars matte black rear spoiler with wicker bill
Clear rear tails + red sequential turn signal
clear rear reflectors
LED rear license plate bulbs
Front brakes at 7-8/32 + near new front rotors, no lip
rear brakes at 8/32 + near new rotors, no lip
Front + rear tires replaced with OEM GY SC3's at 13xxx miles, front at 6-7/32, rears at 5-6/32
Interior
Aeroforce interior gauge integrated in vent pod w/ afr sensor integrated
1LE floor mats
Suede door panel + inner knee panel inserts.
Entire car dynamatted+ acoustic foam. brought interior noise down 10db + improved sound quality from Bose system
Suspension
BMR rear subframe lockout kit
BMR front sway bar links
Xpel Fusion Plus Ceramic Coating
Front Bumper 3M PPF
Both professionally installed 3/22
20% tint installed 6/21
I may be forgetting some things but will add onto the post if necessary. Will also add a few pics to start and will post more after getting it washed.
I have videos of the car idling, it has a nice light chop but nothing crazy, if you want a sound clip text me at 7868771314
Currently asking for 53K, 15kish in parts etc and 1500 for ceramic coating+ppf
Thanks all,
Francis
FKeller is offline   Reply With Quote
Old 03-20-2022, 11:40 PM   #2
FKeller
FKeller's Avatar
Bump, just got the car back from being ceramic coated and PPF put on the front bumper, going to be putting a fresh set of rear tires on this week
Old 03-23-2022, 04:41 AM   #3
ChuckV1LE
ChuckV1LE's Avatar
Drives: Sold - 17 SS 1LE Red Hot - 540whp
Very interested to see what this brings.. have a 2017 1LE w/ 16,xxx miles and similar n/a build that put down 530+.. good gauge of the market.. GLWS
ChuckV1LE is offline   Reply With Quote
Old 04-08-2022, 09:21 PM   #4
FKeller
FKeller's Avatar
Update: Attached some videos from my trip to tail of the dragon, mileage currently at 22xxx. Ran 26-27 MPG all the way on the highway, zero oil consumption and loads of fun carving the corners in this thing!
https://youtube.com/shorts/xVufjpxPQMs?feature=share
https://youtube.com/shorts/1MH6elFcbLc?feature=share
https://youtube.com/shorts/iwX9AeqTHUs?feature=share
https://youtu.be/ToQe4TYxNTA
Old 04-12-2022, 01:00 AM   #5
FKeller
FKeller's Avatar
Dyno date after 5000 miles of new engine break in, put down 503/461 on e70 + mustang dyno here in Miami.
Bump to price: $ 51,500
Old 04-14-2022, 11:48 AM   #6
FKeller
FKeller's Avatar
Found a new car and I need this gone so I have space, don’t really want to trade in and have the new owner in the dark about the car, offers welcome
Bump to 50k
Old 04-19-2022, 03:01 PM   #7
FKeller
FKeller's Avatar
Bump, Dropped to 49k
Old 04-21-2022, 03:19 PM   #8
FKeller
FKeller's Avatar
Price drop: 48K
Old 04-24-2022, 11:45 AM   #9
FKeller
FKeller's Avatar
Price Drop:47K
