Pandora APP On The Touch Screen
Have a 2016 Camaro. For some reason the Pandora APP on the Touch Screen won't connect to Bluetooth anymore even though when I turn my phone on it says the car is connected to the phone and Bluetooth. When I try to open the Pandora APP on the Touch Screen I get an error message that says cannot connect. The App was working up until a week ago.
Try removing the phone and re-adding it.
'22 2SS | Wild Cherry Tintcoat | Design Package 3 | NPP | MRC | A10 | NAV | Ceramic Coating | Full Frontal PPF | New Hood and Side Stripes | Michelin PS AS 4
Range AFM Disabler | Mishimoto Catch Can | Diode Dynamics side markers | Cold Air Inductions CAI | LLoyd Velourtex front/trunk mats with Camaro SS logo ZL1addons Deluxe Rock Guards, Stealth Lift Pads, and Tow Hook | Escort MAXcam360c | Footwell Lighting | Banks gauges in ZZPerformance pillar pod | Paddle shifter extensions |
Tried that already. Unpaired the phone and paired it again. The Touch Screen App still won't connect to Bluetooth.
Do other things work via Bluetooth like playing music from your phone?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Camaro 2SS Hyper Blue Metallic Join Date: May 2020
I thought in order for the App to work you had to be connected via the USB cable connected to Android Auto? I thought if you were just connected to the HU via Bluetooth you just get the basis Music Screen showing song playing, etc... I guess I've never actually tried to use the actual App when connected via BlueTooth. Only when connected via Android Auto. I'll have to try this when I get my car out of storage.
![]() Drives: 2017 2SS, 2023 3LT RS, 2011 2LT RS Join Date: Aug 2014
I dont think the embedded apps on the radio work that way. I think they require an internet connection either through a built in hotspot or from a hotspot.
If you plug up the USB cable and use Android Auto (if you have it) you can use the phone app through android Auto, but just remember they arent the same app and dont work with each other over bluetooth.
'17 2SS ■ HBM '23 3LT RS ■ Rapid Blue '11 2LT RS ■ Red Jewel |
#7 | |
![]() ![]() ![]() ![]() Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
To Clarify: Download the app on your phone. Make sure USB is plugged in. Play app music (in my case iheart radio) then if you look at the Android Auto screen you should see a button for Iheart Radio at the bottom which allows you to control the app on your car's touch screen.
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | Roto-Fab CAI | LT2 Ported | 95mm ZR1 TB | LSA crankshaft conversion w/modified crank gear | LS1 thrust bearing | LS MSD Plug Wire Set | BTR Stage I Cam | ARP Rod Bolts | Delphi Lifter set | NGK LTR71X-11 spark plug set | DOD Delete | VVT Limiter | ECM, TCM & E85 | Retuned by: Justin L. | Dyno: 510 rwhp 472 rwtq | Best 1/4 Time: 11.639
#8 | |
