![]() Drives: 2016 camaro ss Join Date: Oct 2021
Bcm 3
What would cause for bcm 3 fuse to keep going out . Right front turn signal is hyper flashing. I check all fuses. Every time I turn on drl bcm 3 fuse blows out. I even changed back to my oem tail lights and side markers. Also left tail rear tail light goes out too.
I took the all aftermarket lights off .
Sounds like a short somewhere. May a wire is pinched and grounding out against the body.
'22 2SS | Wild Cherry Tintcoat | Design Package 3 | NPP | MRC | A10 | NAV | Ceramic Coating | Full Frontal PPF | New Hood and Side Stripes | Michelin PS AS 4 | Range AFM Disabler
Mishimoto Catch Can | Diode Dynamics side markers | Cold Air Inductions CAI | LLoyd Velourtex front/trunk mats with Camaro SS logo | Footwell Lighting | Umbra Sequential LED Taillights ZL1addons Deluxe Rock Guards, Stealth Lift Pads, and Tow Hook | Escort MAXcam360c | Banks Data Pro and Pro gauges in ZZPerformance pillar pod | Paddle shifter extensions |
#5 | |
![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 2SS A8 Join Date: May 2019
I agree, something is grounding out.
Where should look to see what’s grounding out
#7 |
This what I just got when I signal my drl goes out
#8 |
Disconnect everything you messed with and plug them in one at a time to see what is blowing the fuse.
#9 |
This weird is my brake lights work but the tail lamp is not on. An when I make right turn and use my right turn signal they blow out
#10 |
#11 |
![]() Drives: 2019 Chevy Camaro 2SS Join Date: Sep 2023
